Question about World Office Products Papermate PM-1550CD Shredder
My paper shreder light comes on and cut off frequently it is a paper mate PM-1550CD it is not working what do I do?
electronic & computer repair& servicre
  • 12,061 Answers
Hi, this is usually caused by either a jammed up motor, blown motor or a faulty power supply, either external or internal or both. If one is handy, these may be disassembled and the problem sorted out, either by un-jammimg the motor if jammed or replacement if burnt out, the PSU needs to be checked for volts out, If the Voltage of the external supply, if used, is OK, then suspect the internal PSU, the external unit can be replaced with any suitable same Voltage Current rating a power supply is a power supply as long as polarity is right you are all good.
However most often these types of units are beyond economic repair? Still there is never any harm if one doesn't wish to DIY to get a free "Quote" for repair from a suitable repair shop and go from there?
Posted on Jun 18, 2011
How can I operate the equipment safely?
Just a few I can think of off the top of my head .
Do not over feed shredder - too thick = bad
avoid paper clips and staples going in
Avoid neck ties scarfs near shreder when other end around a neck
Avoid loose clothing near device that can fall into device.
Avoid plastic going in shredder
Make sure waste bin is not full before and while using device otherwise can strain motor.
Do not put water in device or wet paper
Do not operate near water or in rain
do not run shreder on wrong voltage and frequency check voltage from power point matches voltage and frequency required by shredder
do not put tree branches in shredder if designed for paper shredder
do not put cardboard in shedder
If paper gets stuck in shredder use reverse button and remove and try again with less paper . Do not forced shredder to drag paper through it.
Jun 02, 2015 | Office Equipment & Supplies
Sherder also cus off on shreder has no cutting power &no suction
Hi - Shredders don't have suction, but if the blades have gone dull, it can't pull the paper in because it can't cut it. Try one sheet or even half a sheet.
The other possibility is that you are not putting the paper against the paper sensor or the sensor is brokern or blocked. This sensor is usually in the center of the shredder slot. Test it by putting a piece of paper a bit down and seeing if the "on" light comes on.
If the blades are dull, it is probably cheaper to get another shredder on craigslist or staples. I don't know, but am assuming this is a small home office unit.
If the sensor is not working, you can try to clear it.
Investment in repair depends on investment in the scanner. Tell me more and i'll try to research it a bit.
Jan 18, 2014 | Office Equipment & Supplies
My shreder does not work, it is not jamed, it is pluged in, the green light is not on, and it does nothing.
After unplugging my shredder, I turned it upside down and in the area of the shredder mechanism there is a slot that has a little red lever in it. I moved it and tired again and the light came on and the shredder worked. I think it is like a circuit breaker -- we have been having lots of lightning storms and my shredder is not on a surge suppressor.
Feb 20, 2010 | Cross Sentinel 10 Sheet Cut Shredder
Paper shredder does not turn off. I have to open
I'm assuming that it automatically detects the presence of paper... .
By opening the drawer you're disabling it from the safety switch. (they dont want you to shred your fingers from the bottom) There is probably a small piece of paper holding the feed sensor down.
If you're confidant, unplug the unit and take apart the plastic cover. Do not remove anything inside. Look for the small switch between the blades which 'feels' the presence of paper. There is probably a small piece of paper wedged between the housing and the switch which would fool the unit into thinking it has paper that still needs to be shredded.
Carefully put your unit back together and happy shredding.
This may happen often, remember what you did!!!
Jul 30, 2009 | World Office Products Papermate PM-1550CD...
Paper jam. Ready lite comes on but shreder will not start shreding
Common problem with paper shreds blocking the sensors on top and bottom of cutter asm. You may have to remove the top of unit to properly clean. When removing top, be very careful with the short ribbon cable. Lift top slowly and then reach under and disconnect from main board. Once top is off, you can cycle motor by hand and try to remove shreds with needle nose pliers. Of course, disconnect power first.
I’m happy to help further over the phone at https://www.6ya.com/expert/jayw_0e86fb055a7b73de
May 15, 2009 | Tech Solution TS-4500 Shredder
How to clean my jack lalanne power juicer
Take the top part of the juicer off so that just the shreder is visable. On top of the shreder are 2 small holes on either side of the blades. a handle devise with 2 pins came with the juicer. put the tool pins into the holes and twist counter clock wise. The blade will come off then rest is simple and the unit can be disassembled. If you have lost the tool disassembly will be more dificult but can still be accomplished using a cloth on top of the blades and twiting counter clock wise. Careful though or you will cut yourself
Jan 05, 2009 | Jack Lalanne Power Juicer 250 Watts
I have a SX102M paper shreder that wont shrede
It's the paper sensing microswitch. Wire a small toggle switch and drill a small hole for it on the far right side of the top housing. Just remember that the switch has to be turned off when you are finished shredding or the motor will keep running till it burns out
Nov 21, 2008 | Cross Infoguard Shredder SX102M
Need a new nylon gear for the paper shredder
This is how a got my hard to fine gear!
Contact Michael Business Machines for your local dealer 1-800-223-2508
Good luck, Tom
Sep 08, 2008 | World Office Products Papermate PM-1550CD...
World Office Products Papermate PM-1550CD Shredder Logo
Top World Office Products Office Equipment & Supplies Experts
Ekse
Marvin
Marvin
Are you a World Office Products Office Equipment and Supply Expert? Answer questions, earn points and help others
