Hi, F-22 means that the CCU /touch pad/LED assembly unable to transmit/receive
data to/from the CCU central control unit
Possible causes/procedure:
1. Check the touch-pad/LED assembly by selecting different
cycles and changing the modifiers and options available to
confirm the touch-pad/LED is responding.
2. Unplug washer or disconnect power.
3. Check wire harness connections to the
touch-pad/LED assembly and Central Control Unit (CCU).
Your model's tech sheet gives error codes and remedys.
The F22 is a door lock error. When the control senses the door has not locked after six attempts F22 will be displayed.
There may be detergent on the door lock mechanism keeping it from locking. I recommend cleaning the moving parts of the door lock. Also make sure the wiring connections from the CCU (Central Control Unit) to the door lock are tight and in good condition.
If you have a volt/ohm meter and are comfortable working around live electricity I can give you a few checks that will help you diagnose the problem. I have included a wiring diagram that will help you locate theses connectors (see below). I have also included detailed testing information to help with your diagnosing. Always unplug or de-energize electrical equipment before removing covers or attempting service. Be careful and wear appropriate hand protection when working around sharp metal parts.
