Ovens Logo
Posted on Jun 17, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
The oven door locked and will not unlock. Was in prpcess of starting to clean oven when door locked by itself and would not unlock or start cleaning process.
Anonymous
Level 3:
  • Master 600 Answers
  • Posted on Jun 17, 2011
Anonymous
Master
Level 3:
Answers
600
Questions
0
Helped
159153
Points
2012
Hello, Thank You for using FixYa. I will be helping you today.Try unplugging the unit or turning power off for five minutes and see if it unlocks.The lock cycles when power is turned off and back on.
Thank You and please rate my answer if it was helpful..
My 2008 Maytag double oven the lower door is locked, no messages on display and the manual says to push 'CANCEL abd Cook & Hold' button but does not unlock the door
f your 2008 Maytag double oven's lower door is locked, here are some steps you can try to unlock it:
Press Cancel/Off Key: Start by pressing the Cancel/Off key. Wait for 20-30 seconds, then try to open the door. Sometimes this simple latch reset can do the trick.
Power Cycle: Turn off the power at the circuit breaker or fuse box for one minute. After that, turn the power back on. Allow the oven to cool for approximately 30-90 minutes, and then move the latch arm to the left to unlock the door.
Self-Clean Cycle Interruption: If the door locked during a self-clean cycle, select the "Self Clean" option, and then choose "Cancel". Wait a couple of minutes, and then try to start the cycle again. If the self-clean cycle was started by mistake, press the Cancel/Off key. The oven will need to cool to around 200°F (95°C) before the door can open.
Remember to ensure that the oven is cool and the power is turned off before attempting any of these steps. Hopefully, one of these methods will help you unlock the oven door! Your manual might prove helpful. Oven is Locked - What to Do - Product Help ' Maytag
Brandt FP464 Oven Door Locked
On most of these ovens, you can either unplug the unit or flip the breaker from the main and keep it off for ten minutes, then either plugs it back in or turn it back on, and then hit and hold the start/cancel button on the control board for twenty seconds. Yu should hear a beep and then you should see the display light up and ask for you to set the time. If it does this, then the reset has worked. If so, put the oven into a self clean cycle and hit start, listen for the machine to come on, and about a minute later cancel the cycle and see if the door unlocks. If that doesn't work, you may have a bad door lock assembly and you will be forced to manually unlock the door.
To manually unlock the door, stick a screwdriver or heavy wire coat hanger in between the door oven and the door lock and see if you can disengage the door lock. If you manage to get the door open, leave the door open and put the oven into another self clean cycle. If after hitting the start button to activate the self clean cycle, you notice the door lock either not moving or getting stuck closed again you will need a new door lock assembly. If after hitting the start button, the door lock seems to be working fine, the door lock had probably shorted out during the cleaning cycle and looks to be okay now.
Aug 06, 2023 • Ovens
Gibson oven door is locked after attempting to do self-cleaning.
Unplug it. Plug it back in, then press n hold start. Make sure lock handle is all the way locked. You may have to push on the door at same time while locking n unlocking. If that doesn't work, shoot it. Ha
Sep 24, 2012 • Ovens
Tried to clean it. Door has locked and won't cycle open again. Help!
Hello.
To close an oven door when it's in the locked position andthe door is open, press and hold the oven door light switch while followingthese simple steps:
  • Program the oven to self-clean.
  • Wait 20 seconds.
  • Cancel self-clean.
  • Wait 20 seconds.
To self-clean your wall oven, follow these simple steps:
  • Remove the oven racks.
  • Set your oven control to "Clean."
  • Select a cleaning time or choose a cleaning level: light, medium or heavy. For typical cleaning needs, we recommend that you select a cleaning time of three hours or choose the medium setting.
  • Select "Start." (To set a delayed start, see your Use & Care Guide.)
Note: For safety reasons, the oven door will remain locked until the oven coolsdown. When it is sufficiently cool, the door will automatically unlock Thanks for using fixya.
Sep 06, 2011 • Ovens
Started to self-clean, locked the door, etc. Had
Hi.
The appliance door is probably locked in consequence of the self cleaning cycle.
Unplug power cord, and allow the oven cooling down for few hours.
If the is still locked, then the high temperature generated in self cleaning cycle may have damaged the door latch, or the electronic control.
Parts must be tested to discover the fault.
Call Frigidaire at the number listed on the owners manual.
Regards.
Mar 03, 2010 • GE Ovens
Oven door will not unlock
Hello,, Some times this will happen after a self clean cycle if the timer did not finish the entire clean. Try to set the clock to start the self clean again then simply end the self clean. This should unlock the door. If the door remains locked. You may check the oven for an error code, or the door latch itself may need to be replaced. One other possible would be to turn off the power to the oven and try to let the oven control reset. leave the power off for about 15 minutes then turn the power back on. That will sometime work aswell. Good luck and feel free to call me if you need more help.
MIchael Anderson
Anderson Appliance
(865)945-3808
Whirlpool range self cleaning oven door won't unlock after the cleaning cycle was done. gets error code -f5-
I took the back off the stove and manually moved the door locking mechanism to unlock the door. Then started a cleaning cycle untill the door locked. Cancled that cycle and the door unlocked just fine.
Seems OK now.
Oct 15, 2009 • Ovens
2answers
Door locked
resetting thebreaker sometimes will work. if not try setting to clean. after engages the door to clean simply cancel the cycle the door lock/latch will cycleback . perhaps it just glitched shut.
Door Keeps Locking and Unlocking after Power Outage
Located the switch - resetting fixed my stove as well.
Top Kenmore Ovens Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you a Kenmore Oven Expert? Answer questions, earn points and help others
