Hi where are these cables location on the car?
I cant find these speaker cables.
Hi Janhardie57,
Please find the color coding description as follows :-
1-+12 Volt Battery Wire
2-Speaker LR-
3-Speaker LR+
4-Speaker RR-
5-Speaker RR+
6-Booster
7-Power Antenna Turn On
8-Gnd
9-Speaker LF-
10-Speaker LF+
11-Speaker RF-
12-Speaker RF+
13-+12 VOLT IGNITION WIRE
Hope this helps ..:) Let me know in case you have any queries.
If you provide me with the exact model number of your unit, it probably starts with a part number like CDA-, I can help you. they make wiring harnesses for what you are trying to do, so you will not need to do all of the work, at most you will need to crimp wire tips on your wires and slide them into the connector. Again, I need the Alpine Part number and not the Tuner Number. Let me know when you can get this to me and I will help you out.
I'm going to give this go, bear with me because as far as the speaker wires i'm not 100% what color is what speaker.Lets start witht eh power in wire,
the larger red wire is power on from the battery, this aollows the radio to retain the setting.
Yellow is switched power, power that turns on and off with the key or switch.
Black is ground
you will have 8 wires of 4 different colors. those are speaker wires the four different colors there will be a solid color and one of the same color with a black strip on it the solid color is positive the one with the black strip is ground.
you will see 1 to 3 blue wires they are the remote wires for you power ant. amp power they will only have power when the radio is turned one.
If what you are working on is a radio head unit that should give the info you need.
If you dealing with a cd changer or add on please let know so i can better help
M.Woodring
If you are referring to the Pioneer unit, built to Renault specifications, here is the pinout of the DIN connector (click on picture to enlarge):
I’m happy to help further over the phone at https://www.6ya.com/expert/jeremy_69f3cc28d95bf514
I presume you have a "Renault" Laguna?
Here is a photo of the Renault wiring colours (Note: the tweeter wires have been custom-joined at the front speaker terminals - this is optional):
However, I strongly recommend you purchase an aftermarket "Renault-ISO/ISO-Alpine Harness Adaptors", which connects your Alpine unit directly to your vehicle's factory harness.
These ISO car audio harnesses can be purchased fairly cheaply online or at your local automotive car audio parts centre.
Cheers,
sorry you missunderstand my problem, the plug on the stereo is a green single line 15 pin plug which i dont have,i have obtained a similar plug and i want to make up a lead canibalising a male to female iso short lead to fit my cars iso plug so i need to know the colours and positions of the original cables from the grand espace so i can do this,haynes type manuals dont seem to have full wire diagrams now hence needing help as a purpose made lead is not available,hope this clears up the confusion thanks.
hi,ive received your solution but the photo did not come through so i cannot review the wire colours,just to be clear the connection on the unit is a single line 15 pin layout but ive not managed to find a suitable lead anywhere,thanks.
hi my problem is the unit is a 6cd tuner but i dont have the original plug,so from a breakers yard i obtained a similar plug but i dont know the various wire positions on the unit to go with the wires i wish to connect,the wires in the normal iso are familiar to me just the sequence on the units plug so anyone with one of these units in there car should be able to help.thanks
the 6cd tuner has a 15 pin in line plug on the back coloured green not the usual 2x8 iso setup,i plan to make a lead up myself using a short iso lead but need to know the units original wire colours and positions within the green plug if that makes sense,a colour photo of one of these plugs would be ideal,thanks.
hi thanks for your input,the head unit is a 6cd tuner with a 15 pin plug that goes in the back i dont have this plug so i am making up a substitute short lead to fit to my cars iso plugs,i know what all the iso leads wires are but not the relevant places they will take up in the new plug i have made up.what i am looking for ideally is a photo or diagram of the wiring that goes with the unit if that makes sense thanks again.
ive got a renault 6 cd tuner possibly cabasse model no 020366 the plug on the back is a single row 15 pin and my 06 renault laguna is usual 2x8 iso,i cant find an adapter lead so am going to make one,all i need to know is the wire colours and pin positions in the plug a photo would help too,thats as simple as i can put it,thanks.
hi thanks for getting back to me,i will list all the details i can plus i now believe the unit is a "cabasse" model fitted in the higher spec renault cars. A42 AL R92T 17326 020366 8 200 207 099 PN MH9RN92T 04 43 54C03235K 15-0 (barcode) 8 200 207 099 T D787 hope all of this helps fingers crossed and thanks again.
