Televison & Video Logo
Question about GE 25GT507 25" TV
How do I program the channel numbers into my tv?
Posted by hissomj on
Veril Gillette
    Genius:
  • 1,126 Answers
Go to the menu, and pick what type of signal, then it will go to a auto program menu, and at that time is when you auto program you stations.
Posted on Jun 17, 2011
How do I do channel setup?
Find the "auto scan" button or setting in the settings of the TV, it will go through and find all the programs. Make sure the antenna signal is good. There may also be a setting to change the channel numbers manually to match the TV station you select. Most new TV,s will automatically program the Channel number.
What is the code for I can no what channel im on and for my letters and numbers to show on my 7"wide screen lcd tv with atsc tuner tv
      Select and highlight INPUT CONFIGURATION and press ENTER. Using the left/right arrow buttons, select Antenna or Cable as desired, then select DONE. Press the CH RTN button to go back to the TERRESTRIAL menu. Select START SCAN to begin the Channel Program.Aug 7, 2013
      How To: TV Auto Program / Channel Scan - TOSHIBA FORUMS
      forums.toshiba.com/t5/Televisions...To-TV...Program-Channel.../345660
    Feedback
    LG LED TV won't show program information or channel name ...
What does RF CH mean?
What is the difference between a RF channel and a virtual channel? The RF channel is the channel that the TV station uses to broadcast its signal. Before the conversion to digital, TV stations were normally identified by their channel number, and most people knew that a particular network was on a specific TV channel. While analog broadcasting was being phased out and all TV stations were converting to digital broadcasting, it was necessary for the TV stations to continue to broadcast their analog signals on their original RF channels, and also broadcast their digital signals on a different RF channel. However, since the TV station used their broadcast channel as part of their identification, they wanted to keep using the same channel number. To allow this to happen, the new digital television broadcasting standards (ATSC) provided TV stations the ability to continue to use their original channel number and also tell the TV set to tune to the new RF broadcast channel when their virtual channel number was selected. The original channel number is called the virtual channel number, and it will be followed by a period and a second number (3.1, 7.1, etc.).
One of the benefits of converting to digital for the TV stations is that they now have the ability to transmit more than one program at the same time on the same RF channel. The number of additional channels they can broadcast is determined by the resolution of the program (SD vs. HD, text only, music only, etc.). The second number in their virtual channel number indicates that one of the additional programming sources from the same TV station is being viewed (10.2, 10.3, 10.4, etc.).
When selecting an antenna, it is important to understand the difference between the RF broadcast channel and the virtual channel. Antennas are designed to receive specific ranges of RF channels, and the antenna needs to be selected for the RF channel you wish to receive. TV stations broadcast in two broad frequency ranges, called VHF and UHF. RF channels 2 through 13 are considered VHF, and RF channels 14 through 51 are considered UHF. In order to pick up the channels, the antenna has to be designed for the correct frequency range. It is very common today to find that TV stations using virtual channels 2 through 13 are actually using RF broadcast channels in the UHF range. Although not as common, some TV stations using virtual channels 14 through 51 are actually transmitting in the VHF range. An antenna designed for only UHF channels will not work effectively for RF broadcast channels in the VHF range, and an antenna designed for only VHF channels will not work effectively for RF broadcast channels in the UHF range.
2answers
In just bought new Toshiba regza 40" Lcd tv and auto tuned it, but the picture is terible , snowy and colours are not good, what to do...
Hello
First of all reset the TV. for that
press and hold the POWER button
on the TV control panel for 5 or more seconds to reset the TV.
Then connect the TV tt any source like outdoor areiel or cable box etc, select the appropriate input, and retune the TV. First of all, connect it to an external antenna, and set it to autotune.
You must configure the ANT/CABLE input source before
programming channels (-left-hand column).
If the ANT/CABLE input signal type is set to Cable, the
automatic channel programming process erases channels
that were previously programmed into the TV's memory.
If the ANT/CABLE input signal type is set to Antenna, the
automatic channel programming process adds newly found
channels to the existing set of programmed channels (and
does NOT erase channels that were previously
programmed into the TV's memory.) To remove an Antenna
source channel from the memory, you must manually delete
it.
To tune the TV to a channel not programmed in the channel
memory, you must use the Channel Number buttons on the
remote control.
Programming channels when the ANT/CABLE input is
configured for Cable will take substantially longer than when
the antenna input is configured for Antenna. This is normal;
however, once channel programming is finished, you should
not have to repeat the programming process again unless
your Cable TV service lineup changes significantly.
Find out the received channels are clear or not. If they are clear, your TV is perfect, and the input device you connects ot the TV is faulty. OK.
Sony Trinitron KV-27TW77 will not change channels after setting up auto program. Remote or TV will not change channels.
You have not cleared the number of programs tuned in the auto mode,if only one program is tuned than only remote or TV will will not change channels,check by tuning with cable connection with multiple programs,you will get the solution.
I do not have the manual for my JVC TV. Having problems setting the proper channel number to get my Directv stations
Use a generic universal remote. Program the remote to your JVC tv. Use the newly programmed remote to put your JVC tv on channel 3 (or 4) or the appropriate channel for Direct TV.
Tv missing remote. bwant to watch cable tv
many of these require an original remote to program the catv and other functions---check ebay with your model number and see if you can get one.
Tv programming
This TV doesn't have channel labeling. You'll need to keep your cable channel card handy, sorry to say.
2answers
Tv channels
Probably, at first you searched the programs in automatic way. And there were only 20 channels at that time. So, you only have 20 channels. You should try to search channel 21, 22, 23, etc, manually. If you can't set 21 on your program, then your tv set has only 20 programs.
Top GE Televison & Video Experts
Jaime Hernandez
Are you a GE Televison and Video Expert? Answer questions, earn points and help others
