Question about Zenith H27E35DT 27" TV
Goodmorning, bought a zenith tv didn't get the remote. Wonndering how i can programme it using just the buttons on the tv. How do i get the menus up. it only catches threes channels as of now.
Posted by audreanna_95 on
    Top Expert:
  • Zenith Master
  • 76,287 Answers
Hello
There are two types Zenith TVs. One type will have "Menu" button on its front panel and other will not. If your Zenith is the first type, you can programme it without a remote control. If it is the second type, you must have a remote control hanset to programme it.
Programming method
First connect the TVs antenna socket at its back with external antenna or cable.
* With the remote control in hand, press the POWER key to
turn on the Presentation TV.
** Press MENU repeatedly until the Setup menu appears.
*** Using the Up/Down arrow on the remote control, highlight
Auto Program on the screen
**** Press the Right or Left arrow to go to the Auto Program
menu.
***** Using the Up/Down arrow, choose either Cable TV or Off-
Air Antenna on the screen.
****** Press the Right or Left arrow to begin the Channel Search.
******* Press ENTER when the channel search is done.
Note: Auto Program finds channels being received by the TV
tuner
Cable will not work unless you subscribe to a cable service
OK.
Posted on Jun 17, 2011
Have zenith tv with zenith remote working fine. Wrong buttons were pushed trying turn off tv in the dark. Now remote doesn't work. Good batteries. H24F36DT. Ztv. And Zenith tv remote! Non universal..!
I don't have one of these, so a couple of guesses: turn on TV from front panel and attempt to turn off from remote. If that doesn't work turn on TV from front panel and look for setup menus which may have gotten trashed somehow. Take batteries out of remote and leave out for an hour. to see if it resets itself. Have you called Zenith help line?
Service manual: http://www.go-gddq.com/upload/2009_08/09082716157372.pdf
Feb 08, 2015 | Zenith Televison & Video
Zenith remote codes
If it is the original remote control that comes with Plasma TV, there is no need for any set-up codes. It will be pre-programmed to work with the TV. If it doesn't, might have some other fault, either to TV or Remote control.
Jul 02, 2013 | Televison & Video
Zenith a27b41w won't turn on. It just clicks whether using the remote or the button on the tv
Probably a power supply problem. The click could be a relay closing
Nov 04, 2012 | Televison & Video
CAMPORT STUCK on???
I had ot go online to buy a remote control to use with my zenith concierge tv. It is the same model # as yours. I ended up paying almost 40 dollars for a remote made by lg who I believe bought out zenith. I believe you could problably just get a universal remote and get the same thing accomplished. I can do everything with the remote I ordered except the one thing I wanted it for and that is to turn up the volume. It says on the menu, custom, not preset, but it still will only go up halfway no matter what I do. I heard that you could program the tv to factory settings but I tried that with another remote and all it did was reprogram the remote so that it didn't work anymore. If you have any suggestions as to how I can get the volume to work on my tv, I would appreciate it as well
Dec 21, 2011 | Zenith B25A02Z TV
I cannot find picture controls for my tv? No sound controls button either!!
On most TVs, all the picture and sound adjustments are made through on-screen menus. To get to them, you need the original TV remote control (or a compatible replacement) with the proper MENU functions. On some sets there's one main menu to work through, while others have separate buttons for picture and sound control settings.
Some brands and models of TV have a front-panel menu button. Maybe yours does. Sadly, though, many sets now have just a power button and need the remote control for everything else. The biggest trouble I find is that people get used to using the remote that comes with a cable box, satellite receiver or similar device which will turn the TV on and off but that's all. The original remote mysteriously gets lost (I've actually run into people who threw the original control out because they didn't think they needed it), and then you find you can't get at any other TV settings. It's especially annoying if you can't switch to another input, say for a game console or DVD player.
Hopefully, you still have your control. Good luck, and thanks for using Fixya!
Jun 03, 2011 | Zenith Televison & Video
I need the 3 digit device code for Zenith TV Model Z19A11S, to program universal remote.
Hi mwhaken,
You didn't mentioned the brand and model of your remote control, anyway you may try the code below.
ZENITH Codes: 000/ 001/ 004/ 023/ 038/ 058/ 059/ 064/ 121/ 135/ 136/ 153
Let me know the brand and model of the remote if the codes above does not compatible with the unit.
Hope I helped you.
Have a nice day!
Thanks for using Fixya.
May 09, 2011 | Zenith Z19A11S TV
Need the original settings for an 42 LE 530 tv
they is no reset botton .
to reset -switch off your tv from mains plug leave it off for 5mins and switch the tv on.
You may need to purchase a programming remote from LG. The user remote that comes with the TV doesn't have the MENU button. The manual also listed a programming/cloning box by Zenith, I have a cloner box for RCA and it has a reset button on it. I had to download the manual for the same TV from http://shop.retrevo.com/ they didn't have a listing for the LG but the Zenith has the same model # and is the same TV as far as I can tell. You may be able to access the menu using the menu button on the front of the TV . Hope this helps.
Apr 14, 2011 | LG Televison & Video
Zenith B27A11Z 27" TV, can't get into menu, original remote gone
Most universal or multi-brand remotes will control a TV's basic functions, but almost none will support advanced functions like menus. If the TV doesn't have a front panel menu button, the best solution is to buy a universal remote of the same brand as the TV. If you get a Zenith universal remote, it should have a menu button that will work with the TV.
Dec 14, 2008 | Zenith B27A11Z 27" TV
Zenith TV not programmed for home purpose
If you have a remote that can access menu and your remote has number buttons and an enter key, you can follow this instructions to go to installer menu. Note that the installer menu is slightly different for each model, eg. some options are not available.
I was able to go to installer menu using two universal remotes. The remotes that I used were Dish Network 3.0IR and RCA RCU300WBL. Both remotes programmed for Zenith H2531DT TV. The reason why I had to use two remotes is that Dish Network remote was only able to access menu. It did not have ENTER key but RCA remote had ENTER key but I wasn't able to go to menu with that.
To go to installer menu (different from regular menu):
- Hold MENU for 8 seconds.
- Press 9, 8, 7, 6 and ENTER in the sequence.
You should be in the installer menu now. There should be a line that looks something like this:
03 VERT POS 13
Use SELECT button to scroll through each option, and ADJ button to adjust the values for each option. For example, to enable the front panel buttons on your tv, set KEY DEFEAT to 0. Other options that you might want to check:
CHAN LOCK which locks your TV to a single channel and wont let you change (set 0 to turn off)
START CH/VOL will set your tv to a specified channel when you turn on tv. (set 255 to disable)
You will have to look in the menu for some of the options because they are different for different TV series. A good place to find manual is on www.zenith.com or http://safemanuals.com/
I work in an old hotel and it took me few hours to figure out how to disable start channel lock. It drove me nuts. I hope someone finds this useful.
May 26, 2008 | Zenith SC652 Remote Control
Zenith H27E35DT 27" TV Logo
350 people viewed this question
Top Zenith Televison & Video Experts
matt martin
matt martin
 Grubhead
Grubhead
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
