Yes, the upper thread tension on the Jan ome MC 11000 SE can be manually adjusted. To do so, start by loosening the tension dial on the back of the machine until the tension is light enough. Then slowly turn the tension dial back up until you reach the desired tension.
You can probably compare the features and pictures of the two machines. More than likely, the manual would be sufficient for you. Most of the time, the only difference is that one machine may have a couple of additional features or accessories.
Try this link for an affordable solution to repairing your Janome MC 8000 Display Back Light Janome Memory Craft 8000 LCD Backlight Replacement Kit. The kit comes with a custom repair manual specifically written for back light replacement.
Janome no longer supply this component, however they are available in Australia at this site .....just scroll down to find the LCD Backlight to suit the Janome MC 8000 and MC 5700 on this page...HERE
Instructions for installation are also sent in advance so you can decide whether you feel up to the task or would prefer it were done by a technician.
We can also advise your nearest Janome Tech if required, just ask.
The LCD Backlight is prone to going dark eventually and fails progressively, but you can buy a replacement and even instal it yourself.....
We can now supply the LCD Backlight Screen for the Janome Memory Craft MC 8000 and Memory Craft MC 5700.
Keep your old Janome, save money and reduce unnecessary landfill.
It also comes with comprehensive installation instructions from the Original Janome Service Manual which are sent in advance so you can look at the "How to do it" before you decide whether you wish to DIY or enlist the services of a trusted friend or take the LCD Screen and installation instructions to your friendly local technician and have them do it for you.
Here is the LCD Backlight Link
We have about 30 electroluminescent backlights for the 8000 still available .These are not original Janome parts. You will need a Janome service person to install then for you as it requires taking apart alot of the machine to get to the display. We can provide instructions if this person is unsure how to fit. Once the display is out, the process is simple. They are AUD$60 each including shipping. Email at [email protected]
