Question about Razor E100 Electric Scooter
Scooter has new batteries and still barely runs up slight hills its the E 200 scooter
Posted by kariannerage on
Razorbase
    New Friend:
  • 11 Answers
On the Razor E200 check the chain is fully tightened & lubricated & you will be amazed what incorrect tyre pressures will do (36psi) to the power of the scooter.
Posted on Jul 05, 2011
Why does my scooter lose power when going up hill even though its got new fully charged batteries
  1. HI THATS SOUNDS STRANGE IF THEY R NEW BATTERIES. USUALLY WHEN THE BATTERIES R GETTING OLD OR ONE OR BOTH MIGHT HAVE A BAD CELL THIS HAPPENS GOING UP A HILL YOURE CHARGING CIRCUIT MIGHT NOT B PUTTING IN ENOUGH CHARGE ?????? U CANT CHECK THEM WITH A HYDROMETER BECAUSE THEY R SEALED THE BEST WAY TO CHECK IF YOUR BATTERIES R GETTING A GOOD CHARGE BUY A BATTERY load TESTER U CAN GET ONE OF E/BAY FOR APROX $35- THIS WILL TELLU WHAT IS GOING ON ...good luck
Aug 12, 2015 | Health & Beauty
What model/type of battery for gillera st 200
Are you talking about a Gilera Runner ST 200? I'm not familiar with a mobility scooter by the name you mentioned. If you do mean the Gilera ST 200 you can find a replacement battery and info on the battery itself on Amazon.
Piaggio Gilera 200 Runner 200 2010 2012 YTX12 BS Sealed Maintenace Free...
Jan 14, 2015 | Health & Beauty
GOLDEN COMPANION SCOOTER HAS NO POWER TO MOTOR UP EVEN VERY SLIGHT GRADES OR HILLS
If batteries are ok. I would check motor brushed. Make sure they are long enough. Clean and make sure they don't stick. Check colour of comm in motor. Check all connections are tight.
Oct 05, 2014 | Golden Technologies Companion II 3 Wheel...
My mobility scooter loses power when going up a
Possible brushes or weak batteries.
Oct 05, 2014 | Health & Beauty
Whisper mobility scooter
hi, is that the one where the battery case sits on the contacts, if so that is a area you need to look at as this has been a common fault area , the string contacts get weak so losing contact when being jolted etc.
Regards
Jan 14, 2013 | Health & Beauty
My Pride Celebity XL scooter doesn't get full power. Bought w new batterires and still barely makes it up driveway hill.
Hi, if you're charger is suspect it won't matter how good your batteries .
Is it possible to try another charger ?
Are the connections tight on the battery terminals ?,
Where the charger plugs into the scooter ? is it tight or loose ?
Regards
Robin.
Feb 02, 2010 | Pride Health & Beauty
Rascal scooter mo 655 motor stops going up hills
the batteries could be the problem, is it possible to try some other batteries, silly question , how steep is this hill ? remember scooters cannot climb steep hills as the motor will shut down due to the increased load.
1 Year old batteries ok ? but if they get used on a non daily basis and are not fully charged after use, I would question the batteries but again the motor could be overloading,
How much do you weight ? sorry for the personal question but it all loads the motor and that increases the current and that will cause the motor controller to shut it down.
Jun 14, 2009 | Pride New Mobility Legend 4 Wheel Scooter
Razor E100 Electric Scooter Logo
264 people viewed this question
Top Razor Toys Experts
ROB
Andrew Taylor
Andrew Taylor
ray gallant
Are you a Razor Toy Expert? Answer questions, earn points and help others
