Common problem with this TV is the power supply module.
Check the power supply; look for bad caps with leaking/bulging tops, check to see if you have standby +5vdc at the power supply connector, the front red indicator will not be on if you do not have this +5vdc standby voltage due to shorted out transistor and zenerdiode, if otherwise, Your power supply board is dead, u know basic electronics' and soldering? Most of the times, the power supply board just have dead leakages gases capacitors.These capacitors always bulges up on it top,or puff up on it top.Replaced these gases leakages capacitors will get your TV power stable,and work again.Or tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
Hope that this will help in solving the problem, also do take care in handling the fault, because it contains high voltages...
