Http://www.applianceblog.com/mainforums/kitchenaid/17513-fixed-cancel-drain-light-flashing-not-working.html
Hi it's hard to diagnose from symptoms described, but try this post and fix below i am pretty sure this may be whats happening with your unit? Please read right through to the bottom....
Hi You
can unplug it for 2 minutes and then plug it back & try pressing this reset sequence-- Heat
Dry - Normal - Heat Dry - Normal or High Temp - Air Dry - High Temp - Air Dry
or Hi Temp Scrub, energy saver dry, Hi Temp Scrub, energy saver dry. Now let
the unit run for 2-3 minutes and then you press the Cancel/Drain button and
allow it to completely drain and reset. If this doesn't work then it's an issue
with the control board that should be replaced. Hope this helps...please post back for further assistance. Daniel
My control panel has only 7 selections, so I don't have all the selections in your suggestive fix. Control selections are - 1) Heavy Cycle, 2) Normal Cycle, 3) Rinse Only Cycle, 4) High Temp Wash, 5) Energy Saver Dry, 6) Start, 7) Cancel. Any other suggestions?
Regards,
BB
KitchenAid 24 in. KUDI01TJ will not start. Rinse Only and Cancel/Drain lights flashing - won't start
