Toys Logo
Question about Toys
The monitor that goes in my sons room continues to stop working. Ive changed the battery everyday now and by the next morning I have to change it again. Thats the only way to keep it working. I have the plug so i shouldnt need to change the batteries any where near as often as I am!!!! The only thing I know is that the red light comes on the monitor when it is suppose to be green and I cant hear anything on mine.
Posted by bella_9013 on
Ricky Lytle
  • 61 Answers
There is a bad electronic filter in the device and it will always drain the batteries.
Posted on Jun 16, 2011
Sometimes my car just won't start.
If the battery is going flat, then something is draining it. Either that, or the heavy cables that connect to it are making poor contact. Look for green corrosion or white acid powder. Ensure that the ground (-ive) cable is properly connected to the chassis ie remove and replace the chassis bolt. Check also that the trunk light is not on when the trunk is closed. Crawl in or fold down the back seat to check this.
I got 98 navigator run ruff like it haveing aproblem taking fuel ive changed alot of stuff didnt work ive changed the coils fuel filter fuel rail plugwires
try taking gas out n changing it. ethenal is good for that. if you dont drive it everyday water will settle at bottom of tank. of the sock on bottom of fuel pump is stopped up
1helpful
STRIDER MN4 MOBILITY SCOOTER KEEPS STOPPING
Hi. From your description of problems, it sound very likely that your batteries are at fault. There could be other problems causing the above symptoms, but I would definately start by getting the batteries checked at a shop with a PC based battery testing facility. If the batteries pass this test, I would be looking at Brake, Motor or Transaxle problems, as these will all draw from your batteries if not opperating correctly. I would not change any fuses, as these will be fine unless blown. Hope this helps.
We have the Graco two room monitors, says Graco A5220. Our son got ahold of the parent unit, and now the unit will tune in to the room for a short time, then seems to be looking for the other room which is...
1- Set the room switch to the room you want to disable.
2- Press and hold the "stopwatch" looking button on the left side of the monitor.
3- While still pressing the stopwatch button, press the volume down button until there is only 1 LED left on the display.
4- Release all buttons.
5- Change the rooms switch back to the room you are monitoring so you can change the volume if desired.
Sep 13, 2011 • Graco Toys
3helpful
3answers
Cranks but won't start like it has no gas
did you reset the alarm/immobiliser system every time the power was disconnected???
1helpful
Avalanche alarm goes off and key wont start
Try disconnecting the battery cable for a few minutes. This may clear the security code and allow the normal key to operate. The sensor in your tire may have gotten damaged when it was repaired (this is not uncommon). The solution, take it to a tire store, they can change the sensor if needed.
2answers
Calendar/clock keeps changing to wrong date (Nokia 6220 classic)
ok mate its probly ur settings ave ya got it on manuel and if ya do dat wud probly be the problem switch it to auto update and time and that shud do it for ya tell us if it works for ya
2answers
"stopped" in status field
It might be due to the memory being entirely filled up that there isn't enough room for the song you've tried to install, therefore, it might not install all the way on some of the MP3's where others will not install it at all because their system senses not enough room in there to fit it.
Have you tried to delete some space? Also, do you still own this device since it has been a few months since you've posted your question.
Thanks for your patience. Let us know how things are going for you.
Open Questions:
Top Toys Experts
Marvin
Marvin
Tom Chichester
ADMIN Andrew
ADMIN Andrew
Are you a Toy Expert? Answer questions, earn points and help others
