1 - Everytime I use it, waster leaks out around the bottom of door onto my floor.
2 - The "Main Wash" detergent lid doesn't open during wash cycle & dispense detergent. Using a gel detergent.
Drain the dishwasher. There's a box in towards the front of the door. It's shaped like an oval. Carefully remove and clean that. Lift it up and down after and listen for clicking. Try running it again.
first make sure your detergent drawer is not popping open. water will run out from beneath the drawer, run over to the top of the door, run down the door, and then straight down to the floor. If you are not leaking out of the detergent drawer, the next thing down is the bottom of the glass door. look at the glass where it contacts the door seal at the bottom. It should be clean and smooth. Most likely you will find lint, hair, and soap residue. that needs to be cleaned off. any surface imperfections will cause a slow drip or trickle of water to come out of the lowest part of the door. If that is fine, and it is still leaking, open the cover to the drain pump on the bottom right of the front of the machine. Make sure that drain pump filter is tight. run the machine with that little drain access door open and see if you are leaking from there. If none of the above helps, and you are still getting water leaking from the door, miele has designed a new clamping ring for the door seal. Call them and make arrangements to have it replaced.
door gasket possibly bad or another leak. Stop using dishwasher until repaired or you're likely to ruin your floor. I just had this problem before we found a leak and now we may have to replace the kitchen flooring.
Order new clips or the dishwasher could fall out onto the floor or even onto your foot.
it sounds like you need to adjust the door latch so that the top of the door will close tighter. when in the rinse cycle try pushing door at top to see if leak stops. if that doesn't let you know something then you got me. you have changed all that i can think of. Good luck
I bet your clumps of soap began with the beginning of the use of a different DW detergent powder.
Try this (trust me) Go buy a box of brand name Dishwasher powder (e.g. Electrosol or Cascade) Use it for two loads of dishes and report your results back here. OK?
Symptoms: Dispenser lid is open. Caked powder at (what would be during normal
operation) bottom edge of soap dispenser or caked powder fallen onto
dishes or dishwasher bottom. There may be loose powder in rest of
dispenser or spilled down inside door or onto dishes underneath
dispenser.
Solution:
Keep the area around the soap dispenser lid clear when loading the top tray.
Explanation:
The soap dispenser needs to swing open during the wash cycle. In many
dishwashers the top tray has an indentation as wide as the lid of the
dispenser. This allows the top tray to be as large deep as possible
while still allowing space for the dispenser lid to open. People often
pack their dishwasher with things overhanging this gap.
During the wash cycle the catch will release but the overhanging cutlery
or crockery prevents the lid from opening all but a few degrees. Some
water will splash in but not enough to wash out the soap powder. The
soap powder at the bottom of the dispenser will then cake.
When the front door is opened the spring loaded lid, which is partly
open, will of course swing fully open and you'll be convinced that the
lid opened normally during operation. If this is the problem then if
you're very careful and open the door very slowly you can actually hear
the lid flip open. Also, depending on when the lid opens, how far it
opened during operation and how fast you open the door you may find soap
powder spilled down to cover the dishes at the front or down the inside
of the door. This happens when you first open the door and obviously
there couldn't be loose powder there if the powder had emerged while
there was water washing around. Seeing the lid open as you open the door
is a lot harder but can be done on some machines.
Check the rubber bellow (gasket) around the door. This is the symptom of a door gasket that it starting to leak. Pull the rubber folds back and check the area where the gasket attaches to the wash tub. You may have a crack or tear. If the gasket is worn please replay back to this post and I can give you advice on how to replace it and where to get a replacement gasket.
If you are you using a liquid soap or packets that will be the main problem.If your unit fills with water circulates the water and drains the water,and also heaters are working then you probally need to change to cascade powder soap.The film on the dishes is soap.The unit has so much build up in it that when it gets to the rinse cycle it is rinsing dishes with soapy water.You need to get 2 medium bowls fill both 2/3 up with white vinager,place one in upper rack and one in lower rack and run unit on longest cycle letting the vinager splash out during wash.do this with no soap and no dishes.Having soft water will allow you to use less soap.
Before taking anything to bits, check you aren't just loading the machine in such a way that something (for us, it's usually a frying pan) is stopping the soap dispenser from springing open all the way.
A.
