Thomson 20LCDB03B 20 in. Television Logo
Posted on Jun 16, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
LCD TV starts spontaneous. I have removed the batteries of remote control and I have also other remote controls removed. Problem is still there. the control buttons on the sied of the tv doesnt work either ( the power button reacts like a channel up and down button. can you advise me please (Thomson 20LCDB03B) Thanks
COLIN
Level 2:
New Friend:
  • Expert 182 Answers
  • Posted on Sep 02, 2011
COLIN
Expert
Level 2:
New Friend:
Answers
182
Questions
Helped
44346
Points
252
If you have a scart connected remove it and see if this cures your problem
The tv does not responding with the remote control
Remove the battery from the remote.Wait at least 30 minutes. ZReinstall the battery and start over. You will need to reprogram the remote.
The televisor it doesn't start with the remote control and the lateral buttons
Check to see that the remote control batteries are properly installed. They need to point in the direction indicated on the remote. Of course, the batteries need to be good! Perhaps the remote sensing eye on the TV is blocked. Be sure nothing is in front of the TV to block the sensing eye.
Polaroid TLX-01511C LCD TV REMOTE WONT WORK
Change battery and see. Look for any jammed buttons on the remote and/or on the control panel of TV. If you have removed the plug, when the TV was in standby mode, sometimes the system controller could not have got time to reset. Try using the control panel buttons and see whether the TV responds. If not, switch it off manually, switch off power and remove plug and retry after 48 hours.
I have a 32" insignia LCD TV. My remote stop
You can reset your remote control by removing the batteries, pressing all of its buttons, and installing new batteries. Also, ensure that your TV's sensor is clean and unobstructed. If the problem persists, try using a universal remote control as a troubleshooting step. This will help identify whether the original remote or the TV is at fault.
I need to activate my new tv
hi
do the following.
Installation
1. Insert Batteries into Remote Control
1) Remove the battery cover.
2) Insert two size AAA batteries corresponding to (+) and (-) marks on the battery
compartment.
3. Connect power cables
Connect the power cord to the LCD TV then to a proper AC outlet.
IMPORTANT: The power input voltage for TV is 120Vac, before beginning; make sure
all devices are turned off.
4. Turn Power On
Press the power button on the right side of the LCD TV, or press the power (Red) button
on the remote control.
5. Select input source for the LCD TV using the OSD menu or remote
control direct select buttons
6. If connecting to Antenna, Cable or other RF source on TV inputs:
scan and edit available channels.
7. If connecting to a PC(VGA):
For the best picture quality, set the timing of your computer to 1366 x 768 at 60Hz.
Refer to the graphic card's user guide of your computer to set this timing.
if u need further assistance contact me through fixya .
ok
Rca remote control CRK76TA1 has problem w/ sending signal to tv. if i wiggle the eye, it will work for a while. now, no amount of wiggling will work. i have tried removing batteries and pushing every...
Remote is broken.Replace it.
https://www.Abctay.com is an online shop ,
We sell television and electrical accessories,all kinds of TV power supply board, logic board, TV LED screen,
TV LCD screen, mobile phone screen, as well as various types of electronic tools,tv parts power supply,LCD,ccfl ,
LED,OLED,lcd panels,HMI,Inverter,LCD screen,lg screen,display screen,lcd monitor,lg lcd, lg monitor ,flat screen ,
touch screen,hmi,bulb,samsung, innolux ,Mitsubishi,philips, hitachi,auo,innolux,Planar, toshiba, siemens,chi mei,Weinview,
Infineon,industrial LCD,industrial control, sharp monitor,vigor plc,delta, mitsubishi lcd,omron plc,etc.
2answers
Samsung lcd 32 inches screen. The volume turns down to zero by itself. The remote control looses control. Control through remote control keeps coming and going intermittently.volume can be turned up...
Try removing the batteries from the remote after you set the volume, just to determine if the remote is causing the problem or not. I have seen stuff spilled on remotes and they just go crazy.
If you need further help, reach me via phone at https://www.6ya.com/expert/steven_a67ead41eb5fc62a
42" phillips plasma
Hi There, Let's try to isolate the problem. Remove the battery from the remote control. With the battery removed from the remote control, let me know if the menu still appears. Thanks, Mike
Top Thomson Televison & Video Experts
 Grubhead
Grubhead
matt martin
matt martin
Are you a Thomson Televison and Video Expert? Answer questions, earn points and help others
