Re: It says 'lock' on the screen and does not operate at...
This can happen if the Hold or Lock switch is in ON position. Watch is there is any Hold or Lock switch at any side of of your radio. If found then just slide it to off position. If the Hold or Lock button is in ON position it will deactivate all the other switches.
ok
-<~()~>- -<~()~>- -<~()~>- -<~()~>- -<~()~>- -<~()~>- UNLOCKING STEPS FOR A SAMSUNG C120: -<~()~>- -<~()~>- -<~()~>- -<~()~>- -<~()~>- -<~()~>-
Method 1:
1 - Switch ON your Samsung C120 with a NOT ACCEPTED SIM Card.
2 - Samsung C120 will ask for "Password".
3 - Enter the Unlock Code.
OR (if the Samsung C120 shows "Insert Correct SIM Card")
Method 2:
2 - Don't bother about what's being displayed on your Samsung C120.
3 - Compose : #0111*CODE#.
Is it a network PIN? If so, You can get the unlock code for a Samsung Omnia 7 from www.unlock-zone.com/samsung-omnia-7/rs5wp9/ at affordable cost. ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ UNLOCKING STEPS FOR SAMSUNG OMNIA 7 ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ Method 1:
1 - Switch ON your Samsung Omnia 7 with a NOT ACCEPTED SIM Card.
2 - Samsung Omnia 7 will ask for "Password".
OR (if the Samsung Omnia 7 shows "Insert Correct SIM Card")
Method 2:
2 - Don't bother about what's being displayed on your Samsung Omnia 7.
Look at your memory card. SD/SDHC cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Although locking your iPod Touch prevents accidental touch commands, the feature also prevents you from accessing your media and applications while the device is locked, according to the Apple site. The lock code is the 4-digit code that was created when the passcode lock was first enabled, and displays a passcode menu prompt on the iPod Touch's screen when the "Home" or "Power" button is pressed and the unlock bar is slid across the screen.
Instructions 1 Push the "Home" button on the iPod Touch's screen, or push the "Power" button on top of the device to show the home screen. 2 Slide your finger on the iPod Touch's unlock bar. 3 Enter the 4-digit passcode using the on-screen keypad to unlock the device. If you cannot remember the passcode, plug the dock-connector cable into the iPod Touch and plug the other end into your computer's USB port. According to Apple, the iPod Touch will automatically unlock after it is connected to your computer.
Hello When an Insignia TV is locked, it keeps you from watching all of your channels by only displaying a black screen. Insignia TVs are locked from a single button command on the remote control, so it is easy for you to lock the TV by accident. Since Insignia TVs can be locked so easily, it's important to know how to undo this command and unlock the TV yourself. So, unlock your Insignia TV with the push of a button and once again enjoy watching your favorite programs. ·Find the lock button on the Insignia remote control. The lock button is located on the third column from the left on the second row from the top of the remote.
·Stand within operating range of the Insignia TV, then aim the remote at the TV's receiver and press the "Lock" button on the remote control. · Aim the remote at the TV and press the channel buttons to make sure the TV is unlocked. When the TV is locked, it shows a black screen and does not allow you to view anything else. If the screen remains black, press the "Lock" button again. If this doesn't work, change the batteries in the remote and start over at step OK
Make the FixYa experience better for everyone by voting.
My name is Ben and I'm your guru, i.e., mentor, an influential teacher or popular expert: a management guru. - origin from Sanskrit, 'weighty, grave' for today.
PUK Codes
A PUK (PIN Unlock Key) code is required to unlock SIM cards that have become locked following three successive incorrect PIN entries. If your SIM card becomes locked, you will need to get a PUK code from AT&T to unlock your SIM card.
Since I don't know the name of you carrier, I'm using AT&T as an example. Most carriers use the same methodology though the wording may be different.
You can obtain your phone's PUK code from AT&T in one of these ways:
• Log in to myAT&T online • Use our Technical Support Chat. • Contact Customer Care
To get your phone's PUK code online:
? Log in to myAT&T. ? From the myAT&T tab at the top of the page, hover over the Wireless link and select Phone/Device under the My Wireless Service heading. ? From the My Phone/Device screen, select the Unblock SIM Card link under the My Make & Model heading. ? The Unblock SIM screen will display your PUK code and will give you instructions for unblocking your SIM Card.
Once you receive your PUK code, you will need to enter it into your phone to set a new PIN code.
Note: If you enter the wrong PUK code 10 times in a row, your SIM card will be invalidated, and you will need to purchase a new SIM Card. The phone will display the following error: "PUK blocked call operator."
You can also do it without any assistance from anyone, However, be sure to read the following carefully because there are pitfalls.
Although most people remember their primary SIM PIN code, those other codes - used for various verification purposes - are never to be found when needed. Below we've included a set of short codes which, when entered on a handset's standby screen, will let you easily change PIN and PUK (short for Pin Unlock Code) codes - but keep in mind, they may not work with all handsets and mobile operators. If you are interested in a software fix, click on the following link: Universal SIM Lock Remover
More importantly, when changing ones PUK codes there'll be no help to get from the mobile operator if the new codes are forgotten, so make sure to write any changes down alongside the old PUK codes. Also, please note that the codes should be entered without the spaces shown below.
Change SIM Card PIN ** 04 * old PIN * new PIN * new PIN #
Change SIM Card PIN 2 (Write down the new code) ** 042 * old PIN * new PIN * new PIN #
Change SIM Card PUK (Write down the new code) ** 05 * old PUK * new PUK * new PUK #
Change SIM Card PUK 2 (Write down the new code) ** 052 * old PUK * new PUK * new PUK #
Improve the Fixya.com experience for everyone by voting!
Let me give you a little background and then some solutions. This is generic because I don't know your carrier. I'm using ATT as an example.
Phones are naturally unlocked, but a service provider might lock them
When originally manufactured, all GSM cell phones are unlocked. That is, they can be used with any SIM from any cellphone service provider - always assuming, of course, that the cellphone service provider has compatible GSM service on the same frequency bands that the phone can operate on.
Most cell phone service providers electronically 'lock' the phone so that it can only be used with their service. There are obvious reasons why they choose to do this - in particular, to force you to pay what are usually very high roaming charges when you take your phone out of their network and use it elsewhere in the world.
Fortunately, this locking is reversible. With some phones, it is possible to simply enter an unlocking password code into the phone and it is immediately then unlocked. Other phones need to be connected up to a special unlocking data terminal.
Your phone has to be unlocked by the carrier. LG, Motorola, Sony Ericsson, Nokia and most of their ilk, will not give consumers the unlock codes but don't despair.
A PUK (PIN Unlock Key) code is required to unlock SIM cards that have become locked following three successive incorrect PIN entries. If your SIM card becomes locked, you will need to get a PUK code from your carrier. For example, if you have AT&T to unlock your SIM card, you can obtain your phone's PUK code from AT&T by:
? logging in to your my wireless Account online ? using their Technical Support Chat ? calling Customer Care at 1-800-331-0500
To get your phone's PUK code online from ATT:
? Log in to your my wireless Account. ? Select My Services under My Account. ? From the My Services screen, select My Phone/Device. ? Select Unblock SIM Card. ? The Unblock SIM screen will display your PUK code.
Note: If you enter the wrong ATT PUK code 10 times in a row, your SIM card will be invalidated, and you will need to purchase a new SIM Card. The phone will display the following error: "PUK blocked call operator."
There are three other ways to unlock a phone:
? The carrier will unlock the phone for you at one of its retail outlets; ? You can do it yourself by clicking on this link Free Unlock Codes , ? Pay $3.89 at the following website: www.theunlockshack.com/. I have absolutely no affiliation or relationship with The Unlock Shack or its principals.
I trust that this is helpful and solves your problem. All the best
