Question about Danby DDR7009REE Dehumidifier
Looking for replacement blower fan for Danby premiere DDR 7009 REE. The part is ABS D5304-130. Any help?
Posted by jimb1876 on
Rich Landrum
    Brigadier General:
  • 4,736 Answers
If your Danby humidifier is still under warranty, call 800-263-2629. If it's not still under warranty call
800-496-6049.
Hope this helped you. Please let me know. Thanks.
Posted on Jun 16, 2011
Fan running but no water and hot on inside. 50 pint danby premiere dehumidifier
Sarah, The dehumidifier compressor could be bad, may have lost its refrigerant charge or a bad overload protector, have an appliance Tech. check it and estimate repair. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
My Dehumidifier is Not Collecting Water
How to Repairing Dehumidifier
Why does my dehumidifier run but the pan doesn fill with water ShopYourWay
Jul 30, 2016 | Danby Dehumidifiers
What is rightsettingto set at
the general accepted Rh for the avg home is 70% Rh
this is dry enough to not promote mold growth but wet enough that all your wood surfaces wounlt dry out and crack
Oct 19, 2014 | Danby Premiere DDR5009REE 50 Pint Capacity...
I have a danby premiere r410 a, the compressor will not come on
Hi There,
I would love to help you, however I am not sure which model you have. R410A is not a Danby model number. The correct number can be found on the back of the unit as well as on the front cover of the owners manual. The numbers usually begin with "DDR"
Jun 28, 2012 | Danby Dehumidifiers
Dehumidifier Does Not Shut Off
Switch it off when you go out. Find replacement float switch
May 15, 2012 | Dehumidifiers
DANBY DDR7009 REE dehumidifier "Auto" shut off Malfunction
See previous answer. If new, contact supplier to replace float switch. Are you sure it's not just a fan staying on with the tank out?
May 15, 2012 | Danby Dehumidifiers
Danby DDR-7009-REE. This is my 2nd. The 1st unit did not remove any moisture. The new one removes some but nothing as expected. 1700 sq. ft. basement, air temp 62F, no walls-. Humidity is 50%+ and unit is...
It is not working well because of the 62 F temps... the cooler it is in the room the harder it is for the unit to work effectively...
heatman101
Apr 11, 2011 | Danby Dehumidifiers
I'am looking for an owner's manual Danby DDR 451
You can get the manual on the link below. Click on where it says it is free PDF then click on the stars to download.
http://safemanuals.com/user-guide-instructions-owner-manual/DANBY/DDR451-_E
Good Luck
May 26, 2010 | Danby DDR451 Dehumidifier
Danby DDR7009REE Dehumidifier Logo
190 people viewed this question
Top Danby Dehumidifiers Experts
Vincent G
Vincent G
Sheldon Dedek
Andrew Taylor
Andrew Taylor
Are you a Danby Dehumidifier Expert? Answer questions, earn points and help others
