Uniden Cordless Phone Logo
LaVerne Whitelaw Posted on Jun 16, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My Uniden 1560-3 has out of range on all handsets but one. I only have a dial tone on one handset. Please advise how I can correct this problem
castletech
Level 3:
  • Master 372 Answers
  • Posted on Jun 16, 2011
castletech
Master
Level 3:
Answers
372
Questions
0
Helped
102804
Points
1338
Reset the hand sets that are out of range by doing the following:
1) Press and hold END and # for at least five seconds.
2) Move the cursor to select Base Unavailable and then press Menu/Select.
3) Select the base which you want to de-register from, and then press Menu/Select. Base Unavailable appears.
4) Move the cursor to select Yes, and then press Menu/Select. You hear a confirmation tone,
(For DCX150 handsets)
5) Place the handset in the base cradle for about thirty seconds. Handset Registering will appear in the LCD.
6) When the handset has registered to the base, the LCD will display Registration complete then show the handset
ID number.
If the display shows Registration failed, repeat the process again.
(For DCX200 or DCX300 handsets)
5)Disconnect the base AC adapter. Then press and hold find while you reconnect the adapter. Keep holding
find until the charge LED starts to blink.
6)When charged, registered handsets display a handset ID number. Handsets that have not been registered display:
7) On the handset, press and hold # until the handset beeps and displays Handset Registering.
8) When the handset has registered to the base, the LCD will display Registration complete then show the handset
ID number.
User Manual Available Here
My Uniden 1735 will not ring out. No dial tone it is connected to phone line.
If your Uniden product is not performing to your expectations, please try these simple steps. If you are still unable to resolve the problems, please contact Uniden Customer Service for assistance. CHARGING/POWER
Charge light won't come on when Handset is placed in the Base Unit?
There are no lights on the Base Unit?
The telephone only operated after the first time the handset was charged?
The batteries do not work in my new cordless phone?
The charging light colour does not change when the batteries are fully charged?
Should I leave the handset back on the base after the batteries are fully recharged?
The handset beeps?
AUDIO QUALITY
Audio sounds weak and/or scratchy. Interference is evident on my analogue phone?
Interference is evident on my digital phone?
Only continuous static is heard from the Handset and the phone will not turn off?
The handset and base make a humming noise?
NO CALLS
Can't make or receive calls. There is no dial tone?
RINGING
Handset does not ring or receive a page?
The Base Unit does not ring?
CALLER ID
How do I activate caller ID?
How can I access call waiting?
Call waiting is not working?
GENERAL OPERATION
Range is limited?
The answering machine is not answering calls?
Telephone banking is not working?
How do I extend the number of rings?
The clock on the answering machine looses time?
I cannot record an outgoing message?
How do you store phone numbers to memory?
Will my phone work overseas?
What do I do if my phone gets wet?
The earpiece volume is not loud enough?
The ringer volume is not loud enough?
Uniden D3098S I have 2 register hand sets #1 and #2 I have a 3rd one having trouble registerting it to the base iam 2 feet away from the base unit it says check base power & out of range
Registering a Handset
If you see a "not registered" message on a handset, you must register it to a base before using it.
1. On the base, open the menu and select "Register Handset"
2. On the handset, press and hold POUND (#) until the handset display says "Handset Registering" (about 2 seconds).
3. Wait until the handset display says "Registration Complete" (about 30 seconds), then pick up the handset and press eND/CleaR.
# If you don't hear a dial tone or the display says "Registration Failed" charge the battery completely, then try again.
Can a uniden 1560 work with a uniden 1580-2
Please note the DECT 1580-2 and the DECT 1560 are compatible with the following Uniden DECT6.0 accessory handsets: DCX150, DCX200, and DCX300.
3helpful
2answers
My uniden DSS7855 with 1 base station and 3 handsets wont connect when i dial a number and hit the talk button it tries to connect and then comes up "'out of range" much appreciated for any help...
Clear the Handset's Base Data
  1. To remove the base data from a handset when out of range of the base, press and hold the 'end' button and the '#' button simultaneously until the phone beeps.
  2. It will now be de-registered from the base.
Note: This requires that the base and handset can communicate with each other.
Clear the Base Handset Data
  1. To de-register all handsets from the base, remove power to the base, and remove the handset from the base.
  2. Press and hold the 'flash/find hs' button while applying power.
  3. Wait for the beep and release the button.
  4. The charge light will now flash.
  5. Sit any handset in the cradle.
  6. When the flashing stops, re-register the handsets to the base.
Re-Register a Handset to the Base
1. Remove Handset Battery.
2. Reconnect battery while holding down "*" and "#" key.
3. Then press the right upper key under the LCD.
4. Press the "End" key.
5. Wait a few seconds and then the phone will be ready to register to the base.
I’m happy to help further over the phone at https://www.6ya.com/expert/jeremy_69f3cc28d95bf514
No dial tone and no ring on Uniden 5.8 GHz
I have the same handset and the 2nd one seemed to stop working after working great for 2 yrs. I placed both sets together and hit the PAGE button on the main handsets cradle. Both phone's were paged and, for some reason, the 2nd handset reset. It worked for me...or at least, something in what I did worked. BTW, H1 and H2 shows in upper right side (or at least it did after I paged)...and I made sure to put the phones in the correct cradle (H1 is the main handset). I just did this so hoping it continues to work!
2helpful
I have a Uniden DECT 6.0 phone set. I damaged one
On the base, open the menu and select Register Handset. The display should say Handset Registering.
On the handset you want to register, press and hold # until the handset display says Handset Registering (about 2 seconds).
1.
2.
DSL filterTelephone cordTelephone wall jack
45
In about 30 seconds, the handset display should say Registration Complete. Press Talk/fl ash and make sure you get a dial tone.
If...
Try...
the display says Registration Failed --
Making sure the handset is fully charged, then start over at step 1.
No dial tone on handset; cannot make or receive calls
hi there,
better do registering again the phone to the base station. you ma consult your user manual on how to register again the handset.
hope this initial info helps.
2helpful
Handsets read Handset Out Of Range
Disconnected power and phone line, reassembled and then had a dial tone.
4helpful
It may not be registed with the main unit. You may need to register the handset. With my uniden all i have to do is put it in the main base until it says what handset it is (it should be a number).
If you have any questions please dont hesitate to ask
Top Uniden Lands Phones Experts
k24674
Grand Canyon Tech
Grand Canyon Tech
Are you an Uniden Lands Phone Expert? Answer questions, earn points and help others
