Question about Dishwashers
My dishwasher zug adora 555 is flashing A9 and doesn;t start. what is wrong?
Posted by nic_62 on
1 Related Answer
freetek
Steve Allison
  • 5569 Answers
SOURCE: Zug Adora 12s Dishwasher
Perhaps the solution to your problem can be found in the User Guide-
Your model number appears with two suffixes; WW and BB thatmay only be color codes but user guides (which appear to be identical) areavailable for download from GE’s site:
http://products.geappliances.com/MarketingObjectRetrieval/Dispatcher?RequestType=PDF&Name=49-55031.PDF
Posted on Oct 02, 2008
Our 3 month old ge adora dishwasher stopped working properly yesterday. Made funny noise and later I started smelling something burning. Opened it and noticed no water was in it. Restarted and still n
Sounds like the water inlet valve isn't working. Check your house water pressure and make sure it's not above 80 psi. If it isn't, then call a repair company that handles GE warranty work.
Dec 02, 2014 | GE Adora Dishwasher. Built-In Tall Tub...
WHY does my GE Adora GHDA656LSS Stainless Steel Built-in Dishwasher leaves residue on all the dishes after cycle completes? If its a filter problem, where is the filter?
The scum, film and white residue problems have started since the reduction of phosphates in dishwasher detergents.
Here is a tip that will help you to solve the problem of films, residue, and scum in your dishwasher.
Dishwasher Residue and Film on Dishes
heatman101
Nov 29, 2010 | GE Adora GHDA656LSS Stainless Steel...
It doesn' wash sometimes & it won't re-set. It just keeps beeping.
Down loaded owner's manual off GE site.
The door has to be closed enough to lock, if improperly installed it will not lock. It can take up to 90 second's to re-set.
Sep 20, 2009 | General Electric Adora GHDA670N Built-in...
My dishwasher won't actually turn on this morning. When I push the start button, it hums, and the lights by the cycles flash, for about two minutes, but it won't actually run through a cycle.
Your motor is probably stuck.
Remove power from the D/W.
Remove the lower access panel. The motor will be in front of you.
Turn the blades in the end of the motor counterclockwise until the motor turns freely. You will need a flat screwdriver to reach in and turn the blades.
When it frees, repower and try it again.
Mar 14, 2009 | GE Adora GHDA654LBG Dishwasher
Oct 02, 2008 | General Electric Adora GHDA670N Built-in...
GE Adora QuietPower II Replacement Rack Wheels?
Model number is on a sticker on the left wall of the dishwasher, just behind the door, about mid tub level. Post your full model number and I'll list your part number(s) for you.
Sep 06, 2008 | GE Adora GHDA656LSS Stainless Steel...
Dishwashers Logo
70 people viewed this question
Top Dishwashers Experts
Michael Thomas
Michael Thomas
Marvin
Marvin
