Thermador PC366BS Stainless Steel Gas Cooktop Logo
Posted on Jun 16, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My 6 burn cook top when it turn it on it keeps on "clicking
Anonymous
Level 3:
  • Thermador Master 43,501 Answers
  • Posted on Jun 16, 2011
Anonymous
Thermador Master
Level 3:
Answers
43501
Questions
0
Helped
10838302
Points
101584
Here is a tip that I wrote that will help figure out why the burner spark keepson clicking...
Gas Range Repair Burners Keep on Clicking
heatman101
Gas burner continues clicking after on and flame active.
many ovens are made to click like that and nothing is wrong with burner oven, its a safety measure to let you know gas is on or escaping. I f you turn the knob bac or forward a little bit it will go off and flame will still burn. Other words you may have a dirty spark igniter , see pics
Gas Kleenmaid cook top, one igniter continues to
the switch for the ignitor is stuck. might need to free the switch, of
> call the repair man.
We can't turn off the igniter on our gas cook top
Here is a tip that I wrote that will help figure out why the burner spark keeps on clicking...
heatman101
1helpful
Was using 4 burners and they all stopped working- electric burn smell in kitchen. External house breaker is not tripped
When you used all elements the power supply wire have been
gone to the maximum current absorbed so to the maximum heat. When the cook top
is new it can withstand this heat but due to long time used now you have burned
out wires and probably to junction point. So now the power supply wire is
burned and is open circuit thus not any power to the heater. The wires have
just open circuit and they don't touch each other or the metal body of the cook
top that is why you don't have the circuit breaker fuse to trip off. So now you
need to disassemble the cook top and you will very easily find the burn point
which should be melded and burned black and replace all parts that they have
been burned with new one.
Here is the link where you find the parts layout, the wiring
diagram and also order any parts you might need.
Also just for safety, avoid to use all four heater at the
same time in the future.
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5170741&diagram_id=28477270#d28477270
How do you stop the gas cook top lightter from clicking
http://www.fixya.com/support/r4033033-gas_range_repair_burners_keep_clicking
heatman101
3helpful
My indesit gas cooker's igniters keep clicking
Hi yes it could be that if it only just done this leave it off you can still use the top the heat while cooking should dry it out.
4helpful
My ignitor on my ge cooktop keeps clicking slowly in off mode
As it relates to 5 burner gas cooktop Model Number JGP 963SEJ1SS
First - Ignite the flame then reduce the flame to between low and medium.  If the igniter continues to click, you most likely have a contact switch issue related to the problem burner.
Unplug the cook top and turn off the gas.  After the gas is turned off, disconnect the gas line.
Remove the cook top.
Unscrew and Remove ALL of the burner bases by lifting them up.  The ceramic igniters may be difficult to remove but they will come loose if worked out slowly.
Pull of the wire connected to the igniter.
Remove to cook top top plate from the base, exposing the internal gas valves and wiring.
All of the burners are wired in parallel.   Lift off and unsnap the casing of the problem igniter switch.  The repair may require something as simple as, 1- cleaning the contact strips, or 2- slightly bending the non stationary contact strip to keep it from coming in contact with the stationary contact when in the off position, or 3- replacing the switch.
Unless you comfortable and understand how electric systems and switches work, this is a job for a qualified repair person.
Apr 02, 2009 • GE Cooktops
Clicking gas cook top
I accidentally bumped the thing where the gas comes out (I don't know what it's called - I'm a wife not a tekkie) and it started clicking when I turned it on. I turned off the gas and repositioned that gizmo and it stopped clicking.
Burn fuses
Something inside is short-circuited. All components look fine thans to burned fuse. Don't try it anymore with new fuses. You need to get a repairman to check it out.
Top Thermador Cooktops Experts
ZJ Limited
ZJ Limited
Sean Wright
Sean Wright
ADMIN Andrew
ADMIN Andrew
Are you a Thermador Cooktop Expert? Answer questions, earn points and help others
