Close all open programs Click on Start, Run, and type regedit and press Enter HKEY_LOCAL_MACHINE SYSTEM CurrentControlSet Control Class {4D36E965-E325-11CE-BFC1-08002BE10318} This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column. Upper Filters Lower Filters Upper Filters.bak Lower Filters.bak If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
Click on the plus signs (+) next to the following folders
After deleting the keys, close the registry editor
Reboot your computer
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone. if this does not fix the problem
you might have to physically unplug the leads for this cd/dvd then plug them back this should activate the found new hardware wizard or
you might have to uninstall then restart your computer then reinstall your DVD/CD then reinstall the driver for this device
if your computer came with a motherboard disk the drivers could be on it
click start control panel administrive tools computer management device manager scroll down cd dvdrom drives if you see a yellow question or exclamation mark?! or a red x right click you will need to update the driver or
select properties general troubleshoot, select driver click to reinstall drivers click update driver
hope this helps
