I have a Samsung RSH1DBBP. The refrigerator side has gone upto 15 deg and I can not get it back between 1 - 7 deg. This is causing products to go off quickly. Tried pressing the button but shortly after the display goes back to 15 deg
You could have any one of several problems, so it will take some checking by you to figure it out. 1. First check that your condenser grill is not extremely dirty or the air flow is blocked and that the lower fan is operating. 2. Check for an ice buildup around the evaporator coil in the freezer section. If you have it, then your defrost circuit is not operating correctly. 3. If the first two are the cause then it is time to move on to thermostats and control boards.
The accumulation of ice on one side indicates a refrigerant problem. Basically there is a refrigerant leak and some of the refrigerant has been lost.
A technician can repair the leak and re gas the refrigerant for you.
freeze tempt even tho set low / how low is it / must be 0 to 5 deg too work well . it stops at 15 deg .. . make sure both fans are working and the cond coil is clean . .. very important . .. water disp does not work with ice maker . you have a dual valve in the back with two coils . the ice side may have gone bad . if so replace the valve . both sides / only way it comes . hope this helps **** ..
when the ice maker slows down . it's telling us we are having more problems soon the freezer must be 5 deg or lower to 0 deg . for the ice maker to work properly . I think yours is ablut 15 deg . not good . clean the coil in back and ck the fan to see if its going and the one in the freezer . any and all of thes will cause low ice production . hope this helped . **** .
lower tempt in freezer to 0 to 5 deg . ice mker doesn't work till 15 deg or lower . may need to clean coils under neath .. make sure fan motor in back is going ( very common prob w sam .. ) mm
does the fridge have 2 motors or 1 if it have only 1 motor the gas level in the system are low. if it have 2 motors check if the fridge side motor runs
