Westinghouse W4207 42 in. HD-Ready LCD TV Logo
Posted on Jun 16, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
The entire screen is green but the audio is fine.......the tv is about 2 years old....any suggestions?
Anonymous
Level 3:
Master:
  • Master 411 Answers
  • Posted on Jun 16, 2011
Anonymous
Master
Level 3:
Master:
Answers
411
Questions
0
Helped
67351
Points
1264
Is this from the tuner, or using HDMI/composite inputs? If it's HDMI/composite inputs, unplug and replug the cables at both ends. It could just be dust/corrosion on a connector. If it's from the tuner, connect another source through one of the input cables and see what happens.
It's also possible someone sat on the remote, or otherwise changed the settings by accident, or playing a trick on you. Go into the video menu and check the color and tone settings.
My Vizio m55-d0 TV keeps flickering between completely red, blue, white,black and green screens.
Try to turn the TV off and on by removing the power plug. Leave the plug out for at least one hour and then try again.
1helpful
HDMI from new laptop is causing intermittent flickering.
i would suggest a different refresh rate. should be in display properties.
New Proscan 40 goes to green screen when using HDMI cables
I have the same problem with a 40" Toshiba LCD, Component cables work fine with FIOS but not HMDI, goes in and out then blank. HDMI with DVD player works fine. Best buy reported this same problem from users with this toshiba lcd but no solution.
1helpful
Blue wide streaks in my 42" Sony TV model KDFE42A10.
I have the same TV and the same problem and it's also just over 2 years old (bought it June 2006) when the problem started. Every day, I saw the blue streak cover more of the tv, now 6 months later, it has all turned to green and the entire tv has a green tint. It looks like I am watching tv in murky green water.
I am lucky that I purchased the additional warranty on the tv and finally got around to calling them. I hate to tell you this, but they told me that the optical light has gone up and they are replacing the tv.
Blue screen
I would suggest getting another optical block from the repair man. Apparently even some replacement blocks have had issues...
2answers
Westinghouse LTV-27w7 HD TV, two yrs old, blueish square flashing on & off, no picture.
if you have warranty work they will direct you to the service center you will need, I do not know of any bb that service tv's.
5helpful
2answers
TV's on. No Picture...No Sound
Have a problem with Zenith 37 HDTV. Medel number: Z37LZ5D As wathcing TV, along with 'pop' sound, TV went dead. LG service center gave an advice to unplug the power cord and press ON/OFF power switch about 1 min. Then plug power back and turn on the TV. Well, the green light blink for a while and solid green, but still no screen, no audio. Search the Web and someone suggested to replace Power Supply Board which will fix the problem. Again, search the Web and came out with Power Supply Board. LG Electronics/Zenith 'Power Supply Assembl' with $124.95 from PartStore.com. Is it the right solution? Do I have to replace entire Assembly Board? not just replacing some fuse? Any cheaper way to do? If I have to replce PSA board, any suggestion to how? Comment posted on Apr 22, 2009 I have a basic knowledge of electric and electronics, such as rewiring entire house for renovation and assemble entire computer from scratch.
Actually, the TV belongs to my father and the problem that I stated was based on what he told me.
So the question is based on the symptom that I posted, how sure are you that the problem is the Power Supply Board?
Is it good to order PSB? Comment posted on Apr 23, 2009 Purchased 2 and half years ago. Expired one year warranty. Comment posted on Apr 23, 2009 Zohail,
This is LCD TV.
There is no problem with the wall socket nor current.
I put other appliances on same wall socket and worked.
It has to be internal problem.
As I mentioned on the main post, there was a 'pop' sound while watching and TV went dead.
Turn on remote control, there is blink green light and then green stays on, but no sound, no screen.
Turn off remote control, light turns red. Comment posted on May 14, 2009 I fixed the TV.
Orderd power supply board which cost me $136.51 total.
Replacing was simple.
Just removed the rear panel cover then electronic board housing cover.
Took power supply board with all the connector cables and replaced with new one.
Problem was a transformer connector which got burned and blow up the plastic cover.
But no problem with fuse and capacitors.
Thanks all for advises.
2answers
Snowy screen playing dvd's
1.Check audio/video RCA jack cables
2.check S-video(if you use S-video cables)
3.check with another dvd player to get normal picture on your tv system. if picture is normal in this process. then problem with your old dvd player.
4.if same problem occurs in other dvd player. then problem with your television. external audio/video processing circuits
5.if the tv is ok. then the problem with your old Dvd player audio.video converting circuits
6. if can be rectified by authorised service engineers
7.Contact service engineer. as there is no recitification process from user part
15helpful
5answers
LCD TV picture is green
I just called Vizio and they said to unplug the TV, then physically hold in the power button on the TV for 2 minutes.
Black screen - sound works
westinghouse_w32701_27_in_hdtv_lcd
power on no picture good sound and channel page up and down works
on background u can see dark picture
Top Westinghouse Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
Paul Bade
Are you a Westinghouse Televison and Video Expert? Answer questions, earn points and help others
