Question about True T-49 Side by Side Refrigerator Commercial
What is the part number for timmer control of the T49 two door freeze
Posted by thuvu9 on
Luis Calderon
    New Friend:
  • 146 Answers
Is it a Refr. or a Freezer for mthe freezer you can use a paragon model 8141-00-oem D-frost-o-matic timer control................good luck
Posted on Jun 16, 2011
harley
    New Friend:
    Problem Solver:
  • 6 Answers
The part number you are looking for is true part# 831911. Which is the same as the aftermarket part number 8140-00 which is made by a company called paragon.
Posted on Oct 27, 2011
Need installation instructions, pfister web site seems to be down?
http://pricepfisterparts.faucetdirect.com/
Find your model under Bathroom Faucets clik on Sink Faucets scroll down to model T49-CB0
Clik on that model
When that page opens
Clik on the picture of the faucet
Scroll down to the installation pdf document and download from there.
Best of luck!
Apr 17, 2011 | Price Pfister Avalon T49-CB0K Two Handle...
Fan in freezer side runs almost all the time,coils are freezing up,timmer is working, allready changed defrost timmer still freezing over.freezer side is working fine. need help........
There is a problem with the defroster circuit. You already mentioned the timer was replaced. You need to consult your manual for a diagram ( or search at applianceparts.com) to see where the defroster thermostat, thermal fuse, and defroster heater itself are located at, or where the wiring is run.
I suspect your thermal fuse / defroster thermostat has failed.
Jun 26, 2010 | Maytag 25.6 Cu. Ft. Side-by-Side...
My thermostat went bad on my T49 and was
you might have a leak going on clean the coils and check the fan.
Dec 01, 2009 | True T-49 Side by Side Refrigerator...
Whirlpool -ghw9100lw1 wont start sicle
defective timmer, defective water level pressure switch open circuit
Oct 08, 2008 | Washing Machines
Candy fridge freezer
check that the correct thermostat is installed and that the element wire is connected.check door rubber and door hinges.check if it has independant defrost timmers and if it is working.oh and see if the element is drawing current if fitted with one.
Nov 05, 2007 | Engel Freezer 22 Qt. Fridge/Freezer
Evaporator freezes up
No model # .. Im assumeing its frost free.. so that means a defost problem.. heaters, defrost themostate or timmer.
Aug 30, 2007 | Coldtech 21 cu. ft. / 595 liter Commercial...
True T-49 Side by Side Refrigerator Commercial Logo
195 people viewed this question
Top True Refrigerators Experts
Dennis Boxerman
jdthefixer
Muntejaya Ginting
Muntejaya Ginting
Are you a True Refrigerator Expert? Answer questions, earn points and help others
