Question about HP Deskjet F340 All-In-One Printer
I refilled my ink cartridges for My HP Deskjet F340 All-In-One & it is now printing mostly in red with lines running though the document or photo . I tried to print a test page & can not find this option to do so . Can some one help ?
    Scholar:
  • 60 Answers
Hi better replace new ink cartridge and not refill, oftentimes improper refilling damage cartridges. It will work with brand new one.
Posted on Jun 16, 2011
6ya staff
SOURCE:
Do I have to have a color cartridge in order to print? Can I just use a black ink cartridge?
The HP DeskJet 6122 can print with both or only one ink cartridge installed. The printer driver includes an option to print in gray scale as a substitution for color. If you choose to print a document that has a color other than black and white with only a black cartridge installed, I recommend you select the gray scale print option. To select gray scale, select the printer properties and check the box for gray scale rather than color printing. This selection can be made either at the time a document is ready to print (ie., a one time selection, using the "Properties" box in the print options window), OR as a permenant setting using the Control Panel, Printers, HP DeskJet 6122, "Properties" window. Once changed in the general printer properties, these settings remain active anytime the HP DeskJet 6122 printer is selected to print a document.
Sep 03, 2013 | HP DeskJet 6122 InkJet Printer
How do i clean ink heads on hp deskjet f340 all-in-one
Things to clean:1. Little warm water & bowl2. tissue paper3. Ear budsDip cartridge nozzle part in water, wait 10 seconds, take out & swab nozzles with ear buds, clean with tissue paper as shown in fig.. check for the print quality.. repeat two or three times if required.. if no recovery better to replace the cartridge.. 4_29_2012_9_45_00_am.jpg4_29_2012_9_45_32_am.jpg4_29_2012_9_46_04_am.jpg
Apr 28, 2012 | HP Deskjet F340 All-In-One Printer
How to refill the cortrideg hp deskjet f4288.
Hi
the most important is to remove all
the air from the cartridge that has
left inside durring refilling that is why
professionals are using special machines
that refill in 0 air πρεσυρε using vaccum pump
you can check here a video on how to refill
with out any special equipment
Hope I had help you
Dec 08, 2010 | HP DeskJet F380 All-In-One Printer
I have an HP color printer. When printing the black does not print well even though it shows that the black print cartridge has plenty of ink in it. Is there a way of: 1. Diagnosing if it is the print...
Black printer ink in HP Printer may fail to be recognized by the printer. Most times an error message will be sent indicating that something is wrong with the black print cartridge. Sometimes the printer may accept to print with the black ink, but the printouts may have horizontal lines and very illegible letters. In such a case a manual cleaning of the print head should be carried out. In doing the manual cleaning, one should spray Windex heavily on paper towel and wipe off the surface of the print head.
http://en.kioskea.net/forum/affich-40171-printer-not-printing-black
Nov 11, 2010 | HP Deskjet F340 All-In-One Printer
Can you use the HP 27 Ink Cartridge with the HP Deskjet F340?
No you cannot use Cartridge 27 with Hp Deskjet F340 printer. The printer only supports, 21 (black), 22 (color) and 58 (photo). I hope this clears your doubt.
If you need further help, let me know.
Good luck.
Thanks for using FixYa.
Sep 04, 2010 | HP Deskjet F340 All-In-One Printer
Looks like an ink error? All i want to do is scan but it will not let me
I have to ask this question of you, just to make sure this is not an issue. Are you using a factory new ink or toner cartridge?
Please consider the following:
If you are using a refilled or third party cartridges that may well be your problem. Most manufacturers build logic into their products to prevent the use of “Other Equipment Manufactured” cartridges as well as re-filled cartridges.
They do this to prevent problems from contaminated inks or toner causing problems with print quality or damaging the physical printhead or photo conductors.
If you are using factory new ink or toner cartridges, then please call the manufacturer’s Technical Support for assistance with the warranty on the cartridges
Don
Feb 19, 2010 | HP Deskjet F340 All-In-One Printer
How do I refill the HP F340 cartridge? Thanks.
Are you using a factory new ink cartridge?
If you are using a refilled or third party cartridge that may well be your problem. Most manufacturers build logic into their products to prevent the use of “Other Equipment Manufactured” cartridges as well as re-filled cartridges.
They do this to prevent problems from contaminated inks causing problems with print quality or damaging the physical printhead.
If you are using factory new cartridges, then please call the manufacturers Technical Support for assistance with the warranty on the cartridges
Don
Nov 18, 2009 | HP Deskjet F340 All-In-One InkJet Printer
HP Deskjet F4180 Color changes and lines in photo printing
HP always recommend that ink cartridge should be replace by original ink.
As this kind of scenario will occur if the ink will just be replace by a refill ink.
Sep 21, 2009 | HP Deskjet F4180 All-in-One InkJet Printer
Problem printing photos
When printing a photo make sure that your quality is set on best and not normal.
Also check the ink level on your colour and black cartridges and make sure it is sufficient.
Last but not least if you are using remanufactured or refilled cartridges this is a common problem. The cartridges are not made for the printer or they have been refilled and they now have blocked printheads and the ink is doing interesting things. If you buy a real hp cartridge and it should clear the issue up.
Dec 16, 2007 | HP Deskjet F340 All-In-One Printer
111 people viewed this question
Clive
Clive
Ekse
Thomas F. Schneider
