Question about Kenmore 53092 / 53094 Side by Side Refrigerator
Our side by side freezes the food on the refrigerator side in the two lower drawers, fruits and vegetables. I have it set on 2.5 cool.
Posted by md750 on
raj somaiya
  • Kenmore Master
  • 5,370 Answers
The working procedure of the Kenmore side by side refrigerator is as follows:--- First the compressor starts, the compressor is the main part which does the cooling.In the compressor there is refrigerant due to that it does the cooling.------- So compressor starts and it only cools the freezer section.In freezer section there is a evaporator coil.On that coil there is a defrost thermostat and defrost heater.This both defrost thermostat and defrost heater are controlled by defrost board.--- When the freezer compartment gets freezed to its set temperature.At that time the thermostat triggers the defrost board that freezer is cold till its set temperature.So now the defrost board gives command to defrost heater to turn ON.This is the main defrost cycle.In this cycle the fan in the freezer section starts running.And defrost heater starts running.Defrost heater melts the frosted ice collected on the coils and cool air from freezer section transfers to fridge section via the fan.The fan blows this cool air in the freezer section to fridge section.And this is how the fridge section gets cool.From where the cool air transfers from freezer to fridge section, this section is called damper.This damper open and closes by the motor.In defrost cycle damper motor open the damper cover and cool air runs to fridge section and in cooling mode the damper cover remains closed.---------But in your case, everything else is working fine.But damper cover is not closing.Due to this cool air is non-stop running from freezer to fridge section.That is why every thing in two lower drawer is freezing.There is where the damper cover is.---------- Either the damper cover is stuck open.Which you can force bit manually and close.Or the other possibility is, that damper motor is got faulty.And that is why the damper cover is remained open in one position.If the motor is faulty, then complete damper assembly including motor is available, that has to be replaced.---------------Most probably in your case the damper door is not getting properly closed or its stuck open or the damper motor is shorted out.Try to manually close open the door.If it starts working, your problem will get solved.But if its not functioning then damper assembly has to be replaced. ---------------- Many a times the damper door gets over-freezed and due to that this door gets stuck open.In that case i suggest try manual defrost procedure.In manual defrost procedure all ice will be melted from your complete refrigerator.So if this is freezing issue with damper door, then it will come to its normal procedure.The manual defrost procedure is as follows:----- First unplug the unit from main power outlet. Then empty whole unit completely. Then keep both the doors open. Wait for 24 hours. All the ice collected on the coils and in the freezer section will get melted. Clean the water from the sections. Then Connect the power cord of the unit to main power outlet after 24 hours/.Then set the temperature to normal in both fridge and freezer section. It will take near to 4 hours to get run in its proper cooling cycle. Then check, if the problem returns again.If the problem is still there, then replace damper assembly. -------------- To see how damper assembly looks.Please click the link below:--- http://howtobyme.blogspot.com/2011/06/kenmore-side-by-side-refrigerator.html ------------ You can get required parts from from online sites like: --- www.repairclinic.com or from searspartsdirect online site. --------- This should help.Thanks.Helpmech.
Posted on Jun 15, 2011
PSC23NSTESS FREEZING VEGTABLES
Side by Side ModelsIf foods, such as fruits and vegetables, in the refrigerator are freezing, it can be caused by several things. First, check the controls. They should be set at "C" and "5" or "5" and "5". The proper fresh food temperature is between 38 and 42 degrees Fahrenheit. The freezer should be between 0 and 8 degrees Fahrenheit.
  • If food in the bottom of the refrigerator is freezing, this could be caused by a refrigerator not having enough food to absorb the cold air.
  • If food in the door is freezing, move the door bins up or down so they are one notch away from freezer vents (Side by Side models only).
  • The fresh food control should be at the normal setting of 5.
Freezer on Top Models
First, check the controls. They should be set at "C" and "5" or "5" and "5". The proper fresh food temperature is between 38 and 42 degrees Fahrenehit. The freezer should be between 0 and 8 degrees Fahrenheit.
  • Since the cold air coming into the fresh food section originates in the freezer above, the rear of the top shelf will be the coldest spot in the fresh food area. Avoid placing delicate items that freeze easily on the back half of this shelf.
  • If food is freezing in the produce (fruits and vegetables) or meat pan, it may be that the temperature controls are not set high enough. Since cold air naturally falls, the pans can get too cold if the refrigerator is not running long enough to maintain good air circulation. Adjust both controls up one notch.
Nov 01, 2012 | GE CustomStyle PSC23NSTSS Stainless Steel...
Fridge freezing everything
THIS REF. WORKS BEST WITH THE REF. SET ON 4 OR 5 AND THE FREEZER AT 2 1/2 OR 3. HAVING A HIGH FREEZER TEMPATURE CAN HAVE FREEZING IN THE BOTTOM DRAWER OF TH REF. MAINLY BECAUSE OF THE RETURN AIR VENT TO THE FREZER IS BEHIND THAT DRAWER.
Apr 25, 2010 | Maytag 21.9 Cu. Ft. Bottom-Mount...
My GE Profile Performer refrigerator is freezing fruits and veget
PUT THE REF. ON 5 AND SET THE
FREEZER ON 2 1/2 AND SEE IF THIS WORKS
Apr 23, 2010 | GE Profile PSW26P Stainless Steel Side by...
Food (vegetables, fruits) on the refrigerater side freezing
Your model has a control damper inside the vent. The damper opens and closes with changes in temperature. It has a pig tail spiral thermostat on the side and if it goes bad the door sticks open or closed. Sometimes it is just frost but you will need to get to it. I will send photos and links in a moment, Thanks Sea Breeze
Jan 20, 2010 | Amana ARS266ZBS Side by Side Refrigerator
Vegetable and fruit crisper drawers freezing foods
You have a defective thermistor and damper control in the fresh food or a bad control board.
Check the thermistor first.
Also, adjust the return air damper at the bottom left side of the fresh food sction to warmer.
Feb 21, 2009 | GE PSS25SGN Side by Side Refrigerator
Vegetable draw is freezing the vegetables
if you pull out the vegetable drawer, you will notice a vent on the left side in the back. get some tape ( I use aluminum tape ) and cover the bottom half of the vent, that will help keep your vegetables from freezing. that should solve your problem. Joe
Dec 12, 2008 | Whirlpool Gold White-on-White 21.9 cu. ft....
Freezing food in upper chill drawer and freezes water in tank
Does you appliance have the custom cool controls ? If it does then there is another air damper in the custom cool unit at the bottom of the fridge compartment
Aug 28, 2008 | GE PSS25NGM Side by Side Refrigerator
Bottom vegetable/fruit drawer freezing fruit
to the left of the bottom drawer is a veg/meat slide switch.make sure it is all the way on veg.if it is on meat,it opens a small doorway to the freezer and lets the cold air in and will freeze the food in the bottom drawer.in some cases,you will need to remove the drawer and shelf and then take apart the doorway.ball up some putty and jam it it the hole to completely seal it off
Jan 11, 2008 | Amana ARS2661BS Side by Side Refrigerator
Kenmore 53092 / 53094 Side by Side Refrigerator Logo
172 people viewed this question
Top Kenmore Refrigerators Experts
Jimmy
John Tripp
John Tripp
Dale Copeland
Dale Copeland
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
