Question about Galaxy Radios DX-99V 40-Channels Base CB Radio
I want to know where I can buy a Galaxy Dx-99V in Canada.
Posted by danmoral on
Lmax8rn
    New Friend:
I have one. Email me at [email protected]
Posted on Oct 07, 2011
wcrave
    New Friend:
    Problem Solver:
  • 19 Answers
Might be a problem finding a DX99V anywhere. That model has been discontinued. Best bet would be to Google it..
....Don at NTCB, Inc.
Posted on Jun 29, 2011
Galaxy 99v no transmit power on both usb and lsb only. ALC is all the way up. Very low forward about a half a watt only. Looking for answer.
you either bought it used or you played with the inside because if the alc is all the way open then you have been inside it.got a watt meter to turn up the power.you will also need a volt meter. take it to some one that knows what to do and let them fix it.
Feb 25, 2013 | Galaxy Radios DX-99V 40-Channels Base CB...
I have a Galaxy DX 99v and when i key up the frequency counter scrolls up and down on it's one.what can i do to fix it?
the voltage regulator in the freq.counter board is bed and probably a diode common problem that need to go to a professional not a DIY easy job
Sep 17, 2012 | Galaxy Radios DX-99V 40-Channels Base CB...
Would like to know what is the most reliable Galaxy v series, 99 ???, or what is the best opinion of Galaxy in general??
cobra ,is about the easiest to work on and galaxy is good RCI , Midland is secretive , the rest are in the eye of the beholder.
May 03, 2012 | Galaxy Radios DX-99V 40-Channels Base CB...
I have a galaxy 99v when i key the mike the frequency counter jumps around.need help where to locate the problum
sounds like either a bad.mixer crystal or the vco is out.of wacky. if it is the crystal then you can try reseting it. it is a 10.240 crystal. heat the crystal wig a soldering iron for white 8 to 10 seconds. if that doesMr work replace it.
Aug 07, 2011 | Galaxy Radios DX-99V 40-Channels Base CB...
Cant get my 99v to chang channels
Please be more specific. It could be the channel selector to the channel board in your radio, to a slew of different things.
Feb 06, 2011 | Galaxy Radios DX-99V 40-Channels Base CB...
CB RADIO TRC 446 WILL NOT RECEIVE
IF YOU CANT RECIEVE THAT IS A VERY GOOD SIGN THAT YOUR SWR MATCH IS OFF....I DONT KNOW IF YOU MATCHED UP YOUR RADIO WITH YOUR ANT.IF NOT YOU CAN BUY A CHEAP SWR METER @ RADIO SHACK...CHECK THAT YOUR COAX CABLE IS OK TRY TO REPLACE THE COAX......GOOD LUCK
Jan 29, 2009 | Galaxy Radios DX-99V 40-Channels Base CB...
Galaxy Radios DX-99V 40-Channels Base CB Radio Logo
66 people viewed this question
Top Galaxy Radios Radio Communications Experts
eradiostore
eradiostore
Anthony Ward
Anthony Ward
Are you a Galaxy Radios Radio Communication Expert? Answer questions, earn points and help others
