Question about HP Color LaserJet 2600n Printer
The magenta (Q60003A) on my HP 2600N is faded. I have changed three cartidges and the last one is tested on another printer so it is no a cartridge problem What do i do please.
Posted by surjitsc on
Infoprint
    New Friend:
    Problem Solver:
  • 19 Answers
Make manual callibration after install four toner cartridges.The problem will clear.
if not
make cleaning with service people.
Posted on Jun 15, 2011
Color is offset and blurred. There is no problem printing in black. Printing test page shows the same symptoms.
Hello
The color of HP LJ 2600n fades due to following reasons
1. the color cartridge near to empty 2. due to dust on reflection mirrors inside the printer
if the color cartridges are OK, then you need help of HP technician support, because cleaning of mirrors is very technical in nature for 2600n.
Dusty Environments can lead to Laser Scanner Contamination. The dust layer on the mirrors prevents proper transmission of the laser output in the imaging system leading to faded colors on the printed page. The initial stages of this failure typically occur in the magenta or yellow color planes as faded or light color. Often the left side is more faded than the middle.
You may need to contact the nearest Authorized Service Tech and get teh Laser Scanner replaced with the new released service part that has a mirror in a location where the dust ideally cannot reach easily.
Also, please ensure that the printer is relocated from the current location to a more dust free zone.
Hope this helps, if so do rate the solution
Jan 08, 2011 | HP Color LaserJet 2600n Printer
The Magenta colour on my 2605dn is no longer coming out properly (very faint). The cartridge was replaced by made no difference. All other cartridge colours work fine. Tried cleaning and calibrating but...
A faded magenta on this model is probably a dirty scanner mirror.
The printer design puts a fan in an area that blows magenta toner directly at the laser scanner.
The more toner on the mirror, the more faded the print.
You will need to remove the scanner and clean it.
Nov 02, 2010 | HP Color LaserJet 2600n Printer
MY HP ''COLOR LASER JET 2600n'' HAS FUOLL INK CARTRIDGES BUT THE PRINTING IS REALLY DULL AND FADED LOOKING. CAN ANYONE HELP? TERRY M.
This is a common problem with this model of printer. The scanner optic degenration is due to dust buildup on mirrors and lenses. Since the most vulnerable mirror reflects its laser beam to the magenta toner cartridge, red tones are the first to show fading. Colours shift: purples turn blue and oranges turn yellow. The printer will need to be cleaned by a certified HP technician to resolve this issue as it means dismantling your printer to fix the problem.
May 30, 2010 | HP Color LaserJet 2600n Printer
Hp 2600n faded printing
you need to take the scanner out (not very easy to do)unless you are a printer tech.
and clean the mirrors.
Sep 14, 2009 | HP Color LaserJet 2600n Printer
Print is not clear , when we are printing light print is coming, we have already changed the cartridge but the problem is still there
You need to see if the problem is coming from all of the colors or just one. You can print an internal test sheet or just print something with cyan, magenta, yellow and black to see if one or all of them are faded.
If all of the colors are faded and you have already replaced the cartridges then check the fuser unit. It is possible that the toner isn't fusing properly.
Sep 10, 2009 | HP Color LaserJet 2600n Printer
Magenta cartridge not working despite being full
This happens due to Laser sCANNER Contamination.
Light Output that typically starts fading along the outside edges of the media. The first noticable color would be Magenta.
You may need to contact the nearest Authorized Service Tech and get teh Laser Scanner replaced with the new released service part that has a mirror in a location where the dust ideally cannot reach eazily.
Aug 27, 2009 | HP Color LaserJet 2600n Printer
Printer adding magenta checkmarks on every page
After reading other solutions on the web site I decided to look into the hardware itself. It seems I have a faulty magenta cartridge. I do not know why the marks were coming out as perfect little check marks, but that is what threw me off- had they been smeared I would have guessed it was the cartridge right away.
Nov 16, 2008 | HP Color LaserJet 2600n Printer
Every page covered in magenta and black won't print across the page
This is caused by toner contamination in the laser scanner unit, it is quite a complex job removing and cleaning the laser scanner. I would suggest you contact HP regarding the repair.
Sep 04, 2008 | HP Color LaserJet 2600n Printer
HP Color LaserJet 2600n Printer Logo
139 people viewed this question
efs_perpends
efs_perpends
Muntejaya Ginting
Muntejaya Ginting
