Hi, When buttons on a cell phone does not work , it is usually a problem from the Board of the cell phone. An IC problem...
IC are small chips that has different functions on the cell phone. Each IC chips on the cell phone has it's function. The IC controlling the function of the keypads npt working is damaged and needs to be replaced.with another IC chips.
You can get IC chips from your mobile company mini office or you can simply go to the nearest Expert repair store around you area to replace the damaged IC chip that controls the key pad not working.
Sometimes, it might just be dirt or water spill that is making it not to function. You can open the cell phone and clean the keypad area,
Thanks for using fixya...
Please do read the ENTIRE PAGE prior to attempting to enter your codes
Nokia Unlock Codes Generated For Nokia 2600
These Nokia Unlock Codes are Generated For Nokia 2600 with IMEI: 011667002906793 (DCT 4) Locked to ProviderAT&T(Other DCT4) in U.S.A. and will only work with this phone!
#pw+754440272246356+1#
#pw+354116772233126+2#
#pw+746320766415330+3#
#pw+288055103672167+4#
#pw+396496413416000+5#
#pw+837921656511136+6#
#pw+237225755524034+7#
How to Enter your Unlock Codes
Recommended CODE :#pw+237225755524034 +7#
IF UNLOCK SUCCEEDS YOU SHOULD SEE RESTRICTION REMOVED ON SCREEN, YOUR PHONE IS NOW UNLOCKED!
POSSIBLE ERROR MESSAGES:
Repeat above instructions, but with the numbers from code 1 (#pw+754440272246356+1#) if code that does not unlock your phone STOP! . You need to Mail-In your Nokia phone to have it unlocked
