Hello
Your speakers' lead wire has a break in it. Lead wire is one that goes to the speker paper cone, from the connection point. It is a brided copper wire, very thin and flexible. If you be carefull, you can repair it. Speaker lead wire can be bought from electronic spare part shops. Just find out the size use in your speaker, buy a short lenth of it, say half a meter or so [even though it needs a few centimeters]. Look on the spekares leadwire fittings; you can compare the fittings of the other leadwire, and replace it. It is a very keen and sensitive work. After replacing the wire, fix it with some sort of rubber based gum. That is all. OK.
Testimonial: "Thanks"
Back, well it seems my friend was right about the graphite. I just kept gradually adding and mixing it about in the speaker and after some time the speaker started getting clean sound and now plays fine each time.
I'm sure this is no permanent solution, but will also look into the lead wire issue if it has issues in the near future
