Symphonic ST427FF TV Logo
Posted on Dec 26, 2017
I'm not exactly sure what happened, but last night my tv started to have grey 2's in the corners and the number 0f7-0.02 271 followed by a black bordered E5 and has 40 over 2801 in the corner and no matter what I do those numbers won't go away. I can't change the volume or even turn off my tv.
1helpful
Tv wont go past the start screen
I have the exact same problem and am seeking a solution too ... it won't boot past the Vizio logo on the screen and the remote and side buttons won't work :(
Whirlpool gold 4.0 cubit ft. bought 12-18 months ago. with in the last 2 months (not every load) clothes are coming out "eaten". rips and tears, grey streaks, black streaks, etc. thought maybe...
Rearl633, We would like to inquire further about your post with you. Please respond back to this email address [email protected] with your name, user id (Rearl633), phone number, street address, zip code, reviewer name, model & serial number, and date of purchase on the appliance.
1helpful
I've had my Sharp Aquos LC20E1U for a number of years. A couple of times recently it just shut off on its own. It started OK again the following day. However, last time this happened, it wouldn't even...
service menu procedure text changed by midge to work with Sharp LC-32P70E & probably the same for similar models.
There are probably ways of really messing up your set if you do the wrong thing from the service menus, so do this at your own risk:
To enter service menu, make sure the set is plugged in but turned off at the power button on the top of the tv,
then while holding both input button and volume down button, push the power button. Within about 5 seconds, the set will power up keep holding the input and volume down buttons until a small "K" appears in a box on the left side of the screen. Then press and hold the channel down and vol down buttons at the same time to enter the service menu.
Once the service menu is displayed on the screen, you can get the screen to display different levels of solid grey by pressing the number keys on your remote. i.e. press "1" to get a relatively dark grey, 2 for a lighter grey, and so on up to 6 which is a bright white screen; 7, 8, and 9 don't appear to do anything. (this was for adjusting grey levels, other settings are available too) Press any number a second time to return to the service menu...
Not sure wether the grey background settings apply, but for entering the service menu it does.
I think to get out of service mode you have to disconnect the TV from the mains and wait about 30 seconds.
it's some time since I used the service menu on the Sharp Aquos but I do remember you can do a full reset to factory settings as well as turn on, off and reset certain system settings too you will just have to experiment with the remote keys, I think the colour fastext key access different menu levels etc but as I said I am unsure, at least this procedure will get you there so you can try for yourself.
Hope this helps
Please come back to let me know if the service menu procedure works for you.
Good Luck
Midge.
I turned on my TV last night. it did not have picture or sound. the blue light at corner was on around 10 second,and than blinking. can you tell me what happen to my TV.Thank you so much.
Give me model number of set, if blue light just blinks it means short protection--I can tell you exactly what to do to determine what problem is.
SD TECH MAKE A COMMENT HERE OR POST attention SD TECH AND I will assist you.
2helpful
Loss of Color
Have two basic colors blue and yellow or green as the combination all other colors are grey. What are my options...The Boston Celtics Colors are Grey. All others colors are good.
Top Symphonic Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a Symphonic Televison and Video Expert? Answer questions, earn points and help others
