SOURCE: manually openning the trunk of a 2002 porsche boxster
It can only be done using the key fob. Othersise use button inside the car. If your battery is flat you need a donor battery wiring to a connection in the fuse box (positive) anf door lock(negative) but see your hand book.
SOURCE: key lock on drivers door won't unlock the door
you need to take the door panel off, there is a rod in there that connects to the lock cylinder it frequently pops off, there is a little plastic clip that should hold it on to the cylinder it may be broken!!
SOURCE: 1999 porsche boxster cannot lock car with key or
Try replacing the battery in the key. It may be too weak to engage lock.
SOURCE: 1998 Toyota Corolla Electric Door Lock Problem
You'll need to replace the solenoid (motor) that doesn't work. Not hard once you get the door panel off. I suggest you buy the correct part, not a universal one.
SOURCE: porsche boxster 1998 squeaking suspension
I had the same problem on my 2004 Boxster.. It is the outer ball joint.. I filled a Syringe with liquid grease and poked it through the Ball Joint boot to squirt it in.. Problem solved and small hole in the boot not noticable..
