Question about Xact Communication XTR1 SIRIUS Radio Receiver
Metal prongs on the antenna wire that plugs into the back of my Sirius radio have broken off. Can they be replace?
Posted by cvfd6303 on
TSS Radio
    New Friend:
  • 62 Answers
There are a couple of different ways the antenna connection can break. Docks and antenna replacements are available, though the actual prong itself may be difficult to track down.
Posted on Jun 15, 2011
I have a 2009 Dodge Ram pickup with factory sirius radio. When I put my cab over camper on it I lose the sirius radio signal. Is there a external antenna that will work with setup . I can mount it on top...
We had the same issue with our 2007 Dodge Ram truck. We use an external antenna when we have the camper on. You can buy these at various places on line. Get the car antenna not the home antenna. It magnetically mounts onto the truck so we put it on our hood and routed the antenna wire through the passenger side door. Our satellite box is behind the glove box. Remove the glove box and look up in the cavity. We were able to just unplug the factory antenna and plug the external antenna in. It's easy to switch back too. Just be careful with the antenna wire because it's fragile and any little bit of damage makes it useless.
Jul 04, 2010 | Sirius Satellite Radio Receiver
Antenna not detected what could this be
Usually the antenna is not plugged-in all the way, or you have broken the little tiny antenna wire. Try another location first, then try another antenna.
Jun 14, 2010 | Sirius Sportster 4 SP4-TK1 Satellite Radio...
My sirius portable radio keeps displaying "no antenna detected" but it's plugged in.
Several possiblities: one: antenna really is bad - borrow a friends Sirius or XM antenna and plug it into the base and see if the message goes away -if it does, replace antenna; if not, then your 'dock' or base could be bad - try removing and reinstalling the radio or try another base. If another base and antenna don't solve it, then the radio is shot and it's time for a new one. Customer service will ususally give you a great deal on a new XM radio IF you agree to keep it for 1 year. Let me know how it goes.
Jan 12, 2010 | Audiovox SIRPNP2 SIRIUS Radio Receiver
Antenna not found sirius satellite radio
You may have a defective satellite antenna or cable
Nov 09, 2009 | Sirius Satellite Radio Receiver
Broken antenna jack on a Sirius Stratus 5
Are you missing the center pin, by chance (which often snaps if the plug isn't lined up correctly or if you wiggle the lead to connect or disconnect)?
I fixed mine by inserting a 1.5CM piece of very thin but stiff copper wire into the dimple. You may have to 'coax' it a bit with needle nose pliers.
Crat
Oct 25, 2009 | Sirius Satellite Radio Receiver
Sirius satellite radio constantly shows "acquiring signal"
it could be the connection on the back of the reciever that could be bad. I would call sirius and see if your reciever is under warranty still, if not i can almost garauntee that your tuner antenna input is bad, if your antenna is brand new.
Apr 15, 2009 | Sirius Audio Players & Recorders
Receive "Antenna Fail" on receiver
Same problem on my CX-7. I've had antenna replaced one so far. It takes about 30 minutes in the cold (usually on at night on my commute home) to get signal. I agree, during the summer months, everything works fine.
Dec 31, 2008 | Sirius Satellite Radio Sirius SIR-ALP1...
Signal Fading In and out
Most of the Xact models use the standard Sirius antenna. Unfortunately Xact no longer supports satellite radios. You can get a replacement antenna from any Sirius dealer and see if that works. Sounds like the antenna wiring might be broken or shorted out.
Dec 25, 2008 | Sirius Satellite Radio Receiver
Sirius Antenna
There are several ways to tackle this problem, most of which would involve getting to the back of the radio, but before you do, make sure you have an "antenna extension cable". Then plug in the 'extension cable to the radio/sirius unit' leaving the other end to 'hang out' where you can then get access to the 'extension' cable. Then you can plug in the existing antenna when you're not using the camper or plug in new antenna that gets clear view of the satellite. Depending on your location and general direction of travel you may be able to use a 'home unit ' antenna on your dash as I do and it works very well. In my truck I often use a home antenna also, although I also have the large unit that bolts to the (tractor) truck mirror assembly.
The other solution is to find a CB repair place (often at truck stops) that is familiar with repairing, satelite antenna wire and pucks. Have them split the wire and place a male and female plug to accomodate the extisting antenna and the new antenna. This service will cost you about $30-50.00 They should find the parts needed at a satellite radio store that sells marine/business/home antennae systems. The parts are not all that common - or the CB fellow may connect male/female connectors that are unique to your truck situation - then any connectors will work but only on that truck of yours. -- Frank
Sep 15, 2008 | Audio Players & Recorders
Power supply to Sirius Radio
yes, some sirius radios work on 5 volts, and some work on 12 volts. Your sportster replay is a 5 volt unit. If you trace that wire back, you will find a cigarette lighter plug with a transformer built into it, with either wires soldered to the terminals, or a female cig plug wired up behind the dash. Whatever sirius unit you plan on hooking up, I strongly reccommend using the transformer that it came with......however if you're willing to take a chance, it's most likely 5 volts.
Aug 18, 2007 | JVC KT-SR1000 SIRIUS Radio Receiver
Xact Communication XTR1 SIRIUS Radio Receiver Logo
Top Xact Communication Audio Players & Recorders Experts
Are you a Xact Communication Audio Player and Recorder Expert? Answer questions, earn points and help others
