SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard Drive Logo
Question about SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard Drive
2kb shortcut problem in pen drive...how to clear it..?
Posted by arun_smartgu on
Anonymous
    Brigadier General:
  • 10,406 Answers
Click the mouse's "second" (usually the "right") button on the icon for the shortcut, and choose 'Delete', to remove the invalid shortcut.
Posted on Jun 15, 2011
Why in my pendrive all the data we trancefer are come in shortcut
Probably you just copied a shortcut to the location of the files. You need to go back and verify whether this is the case.
Processing is very slow
it seems your computer or the pen drive or both virus infected.
press win button + R - type cmd - type H: (if your pen drive recognized as H or (whatever your pen drive's drive letter)
then carefully type the following without bracket [attrib -r -s -h *.* /s /d]
press enter. now check your pen drive. if you could not, inform me i'll give images with explanation
1helpful
2answers
Pen drive shortcut problem
Try Shortcut Virus Remover.
It will work against Shortcut Virus.
You can download Shortcut Virus Remover from this link for free,
How to remove shortcut virus from microsd memory?
There are many ways to remove Shortcut Virus.
Use Shortcut Virus Remover. That is the easiest way.
  • 100% free application
  • 2KB of size
  • Just a one Enter to remove the effect from Shortcut Virus
Download the Shortcut Virus Remover from bellow link. Place it in your memory card or flash drive. Double Click (run). Press Enter to confirm to start its process. That is all.
Your Problem will solve.
Download Link - Shortcut Virus Remover
How to solve shortcut virus
There are many ways to solve Shortcut Virus problem
  • 2KB of size
  • Just a one Click to remove the effects from Shortcut Virus
164helpful
8answers
Removal of shortcut virus in pen drive
Is this the Problem???
Don't format your Flash Drive.
Your data is still there.
  • 100% free
  • Setup file to download 1.1 Mb
  • Installed file 2 Kb
It will recover your all data.
DOWNLOAD !!!
2helpful
2answers
My folder's turned into 1 KB Shortcuts on my 500 GB WD Hard Drive, it seems like memory in my HD is used, but when i click in to open folder it says that file cannot find :(
Well, it's obviously your external WD drive infected with virus which stop you from accessing the data by turning them into shortcuts (such as 1KB or 2KB). This blog article how to fix folder become shortcuts should help you out. Follow the step by step please. Note: do not attempt to format the drive before you try.
4helpful
All folders in pen drive become shortcut
Your pen drive probably was infected with some some kinds of virus or trojans. See this blog article how to fix file folders shortcuts problem step by step. Hope it helps. Regards
Aug 14, 2010 • Cell Phones
Creating shortcuts of folders in my pen drive and I am not able to delete them as the shortcuts are again coming after deleting
If you are using windows 7 or vista.....just insert your usb drive in your computer then there will appear "SCAN AND FIX" window.
Now click on scan and fix.....
your shortcut error will remove from your usb drive.......
Top SanDisk Computers & Internet Experts
Steve
Marvin
Marvin
Are you a SanDisk Computer and Internet Expert? Answer questions, earn points and help others
