Question about Motorola Mag One BPR40 Two Way Radio
My magone BPR40 radio isn't sending when PTT is pushed. It is receiving fine. Any suggestions?
Posted by abetz586 on
eradiostore
  • Motorola Master
  • 1,658 Answers
A couple of thoughts:
1) Check the mic hole and see if it is covered or clogged with debris.
2) Does your PTT button seem hard or the opposite, mushy? You could have an internal PTT issue. The PTT is a common failure part on 2-way radios. Feel around for the 'sweet' spot and see if you can make a simple or partial transmission, or if it will even momentarily open up the receiver on the other unit. If so, your radio is in need of repair. It would likely need a new internal PTT. (At most repair centers where the BPR40 is repaired the flat rate repair currently are around $69 for the BPR40)
3) Has any reprogramming been recently done on the radio? If so, double check the programming to be sure your PL/DPL code is set the same as your other radio.\
4) Check your battery. Trade batteries with the other unit and see if the problem changes. It takes more energy to transmit than to receive.
Best regards.
Posted on Jun 16, 2011
BPR40 Receiving a static reception when someone is talking
Several things need to be checked. Fully charged battery. Antenna, make certain it s tight and unbroken. Wiggle the antenna while receiving, if reception improves, it is the antenna or the antenna jack. Then wiggle the on/off vol switch, same thing, if reception improves, it is broken or needs to be resoldered. Then I check the speaker. Speakers gather metal particles, as they get more and more, the speaker distorts and it sounds like static. Use a powerful magnet, run it over the speaker grill and see if anything comes out. I put plastic wrap on the magnet for easy cleaning. It could still be a bad speaker. Last, I check programming. All of this is done at our shop regularly and I suspect most radio shops follow the same procedures, maybe in a different order. Post if this helps or not.
May 17, 2016 | Motorola MagOne BPR40 UHF 8-channel...
Magone bpr40 - How do you remove the Board from Metal back plate. All Screws are now off of board, But still not coming apart.
Great question! Clear and easy to understand! The volume and channel switches likely have a metal "O" ring that screws down on the threaded switch and holds the top of the radio to the housing. Remove the knobs, then use a really small flathead screwdriver, insert it into a notch in the "O" ring and unscrew. Be careful and you should be fine. If not, get it to a radio repair shop.
Apr 16, 2015 | Motorola Mag One BPR40 Two Way Radio
How to I syncronize all my radios so they work together
Karen-
Contact Motorola Solutions
Get Support
Mark
Motorola Mobility Support
Jan 09, 2015 | Motorola 4 Magone Bpr40 Uhf
How do you synch a set of Motorola MagOne BPR40 radios to a new set of the same radios?
BPR40 radios are dealer programmable using Motorola proprietary software and cable.
Jun 23, 2014 | Motorola Mag One BPR40 Two Way Radio
How do i sync Two-way radio AAH84RCS8AA1AN
These are dealer programmable using Motorola proprietary software and the appropriate cable. Most Motorola dealers could program one or more of the radios for you.
Mar 16, 2014 | Motorola MagOne BPR40 UHF 8-channel...
My BPR40 transmits to one radio but can't respond ?
Check your PL/DPL settings among the radios. You may not have them programmed the same as one another. PL (aka private line) blocks out other users who do not have the same code as one another. Your radio which receives could be set with no PL code and it receives and hears every thing, so it would hear the other two, but not talk to them if they have a PL code setting.
Another way to check this is typically the dealer who programmed them will have the side button directly under the PTT programmed for Monitor. If you press this button a short press you should temporarily go into "open squelch" and you would be able to hear everything on your frequency. Try pressing this button on one of your "two" radios and see if they can hear the "one" radio. If so, you know it is a programming issue. (provided the button is programmed to Monitor). If pressing the Monitor button does not allow temporary communication, you have another issue.
If the green light on the radio seems to come on and stay on continuously, the radio is in need of repair. (Average flat rate repair on tehese BPR40s are around $79 currently at many repair centers.)
Best regards.
Jan 14, 2013 | Motorola Mag One BPR40 Two Way Radio
Re: MagOne by Motorola, BPR40 -- What button should I push and how many times to make a radio stop beeping repeatedly before I can communicate? Thanks!
None of the buttons will solve this issue.
A repeating low tone is heard when you press the PTT if your battery level is low. You may have a bad or poorly charged battery. It takes more energy to transmit than to receive, so the first place this shows up is when pressing the PTT. A quick way to check this is to swap batteries with a known good radio and see if the problem switches to the other radio.
Battery tips: Clean your battery contacts with a pencil eraser to remove the film caused by hand oil. Always charge your battery with the radio turned off. And be certain your charger is plugged into an outlet that is not connected to a light switch shutting off power. Batteries last approx. 2 years. Check your battery's date code to see its age. (3 or 4 digit number, first one-two numbers are the year, second two are the week of the year. example: 1132 would be 2011 the 32nd week)
If the above does not solve your problem, you should see your local Motorola dealer, or a nationwide repair center for more assistance. Current flat rate repair on this style unit is typically around $69.
FYI: Your buttons are likely top button = monitor/sticky monitor and the bottom button could be hi/low power, scan or one of several other features. Each button has a short and a long press option.
Best regards.
Aug 09, 2011 | Motorola Mag One BPR40 Two Way Radio
Are my Motorola MagOne BPR40 handheld radios narrowband capable?
Yes. They are programmable to either wideband or narrowband on a per channel basis.
Best regards.
Feb 16, 2011 | Motorola Mag One BPR40 Two Way Radio
We currently have a fleet of 12 MagOne BPR40's. They need to be cleaned, but I'm not sure how to clean them, or even how to take them apart. Any suggestions??
At our repair shop we use a very mld cleaner that we get at a local "dollar" store. I think because it is so cheap it isn't strong enough to hurt anything. We spray them from afar with a light mist and then use a old toothbrush to scrub tough areas. Michael
Dec 14, 2010 | Motorola Mag One BPR40 Two Way Radio
Motorola Mag One BPR40 Two Way Radio Logo
411 people viewed this question
Top Motorola Radio Communications Experts
eradiostore
eradiostore
Jane
Level 1 Expert
Muntejaya Ginting
Muntejaya Ginting
Are you a Motorola Radio Communication Expert? Answer questions, earn points and help others
