Try logging on to gmail from a desktop or laptop.
Click on the "Contacts" link on the top lefthand side.
Are all of your contacts listed there? Now select every contact that you want to see on your phone.
Click the 'Groups' button and select the group 'My Contacts'.
On your phone activate the 'sync contacts' again. You should now have all of the contacts you just selected on your phone.
This is happening not because of Gmail contacts sync. This happens due to setting in Contacts application which is not showing phone contacts.
To solve this problem,
1. Open Contacts from Menu
2. Press Menu button (first button on phone), select "view"
3. You will see option to view phone contacts, gmail contacts,Facebook contacts (if you have setup Facebook) etc.
3. Check "Phone " and you will see phone numbers also in contacts.
TIP: You can check " Only show contacts with phone number" to hide email only contacts.
Reply in case of any problem.
To control sync settings for the device, follow these steps:
Android 4.0 / 4.1 / 4.2
Android 2.1 / 2.2 / 2.3
Android 1.5 / 1.6
Go To > Menu > Messages, Click Settings > Email
Then Touch >Email Setup Wizard. Notice will ocuur Touch > OK
Give name to your account E.g Gmail. Enter your email id : [email protected] , Then Enter Password for your account.
Incoming Server type : POP3
Incoming Server : pop.gmail.com
Outgoing Server SMTP : smtp.gmail.com
Secured Connection : Off
Then touch OK & it will display your POP3email account configured successfully. Now press back button and tap on Email Accounts, then touch the email account you have just created. There some more option than above you just have to edit that.
Secured Connection: Off
POP3 Port: 995
SMTP Port : 587
Now, Tick The option APOP Login.
Download Limit: 500
Secured connection: SSL (Choose SSL for second option only & not for first option.)
Retrieving Option: Choose Subject only
Keep On Server: Tick
My Address: yourname @gmail.com
Username /Password : same as you entered above
POP before SMTP : Dont Tick
SMTP Auth: Tick
Same as POP3/IMAP4 : Tick
And Finally Save All Settings.
