Contributor
- Posted on Jun 19, 2011
Re: I need instructions for the genki house baby carrier...
Here are Genkihouse Sling instructions - I tried to attach scanned copies of the instructions, however it exceeded the file size limit:
For front use
- Hold your baby close to your chest
- Still holding baby close to your chest, grab sling and place over baby - Genkihouse logo facing away from you, arrange baby's legs through leg openings. Alternatively, you can lay the sling on a change table with logo facing down, lie baby on top and put legs through leg holes then lift the baby and the sling onto your chest.
- Still holding baby close to you, place sling straps over your shoulders.
- Reach behind with one arm (still holding baby with the other) and firmly take the strap from behind opposite shoulder. Your other arm still holds the baby and sling.
- Thread the strap through D ring with one hand whilst your other hand still holds the baby.
- Simply 'hook' the strap through the D ring with your index finger.
- Do not change hands at this stage.
- Tension strap backwards - away from your back and don't let go.
- Feel the baby's weight now firmly supported by the sling at your waistline.
- As you continue to hold the same strap reach behind with the other hand and thread the second strap through its D-ring. The straps should criss cross over your back.
- Bring straps together, adjust tension to suit and tie a secure knot in the middle of your back.
- Check the position of the baby - you should be able to kiss his/her head.
- Baby can also face outwards when he/she gets older.
