There is one under the hood, under the drivers side dash and another on
the passenger side under the dash. you have to remove the bottom cover
on the passenger side fuse location should be on the cover you removed.
Turn off your car before you work on replacing any fuses. Find the main fuse box by looking under the hood in the engine compartment
Lift the cover of the fuse box to expose the fuses. Look at the cover
to find the location of each fuse housed there. As an example, the
Bonneville headlight fuses are found in slots 5 and 6.Remove the fuse and check the middle wire. The fuse is blown if the wire is melted or broken
Read more: How to Replace the Fuses in a Pontiac Bonneville ' eHow.com http://www.ehow.com/how_4507545_replace-fuses-pontiac-bonneville.html#ixzz1PNEumuqk
