There shouldn't be a reset switch. The only units I've ever seen or heard of having a reset switch were old Rheem condenser, they had a high pressure switch that you could reset by pressing a red plastic button, but even Rheems no longer have them and I've never heard of Goodman using them.
What problem are you having with your A/C system? And why are you looking for a reset for it? Please repost your question and give us a bit more info so that we may help you with your probelm.
The outside unit fan kicks on and the inside unit does not. There is a puddle of water around the unit and there is ice on the pipes coming out of the unit.
It was making a "buzzing" sound but would not kick on. Now, it is doing nothing.
SOURCE: where is fuse located on goodman ckl60-1 ac unit?
I'd be surprised if you had a fuse in either the outside or inside unit. Typically the fuse(s) are mounted in a gray electrical box (on the house) near the outside unit.
You can usually - easily see the fuse box but if you don't just follow the electrical conduit from the outside unit - to the fuse box.
good luck!
SOURCE: goodman ac unit won't come on at all
ALSO CHECK FUSES IN BOX ON OUTSIDE WALL . SHUT OFF BREAKER BEFORE FUSE CHECK. BREAKER MUST BE TURNED ALL THE WAY OFF THEN BACK ON TO RESET
Check all the easy things first. Check that all the settings on the thermostat are correct for AC. Does the AC unit run? If not check the electrical panel breakers to see if the AC unit breaker is tripped. If it is tripped, reset it. If it continues to trip, call are reputable service company. There are little or no items for "do-it-yourself" unless you have the training and equipment to service AC. Good luck.
