Question about Poulan Pro PR550N22SH 22Inch Briggs Stratton 550 Series Gas Powered Side DischargeMulch Lawn Mower With High Rear Wheels (NonCARB Compliant) ()
I have a poulan pro 550 series B&S 158cc push mower. it sounds like a moved the choke when I went under a bush, because its running at a lower rpm. However, I can't find a manual choke.
Posted by killabal on
dannydoesita
  • 776 Answers
The first thing I would do is , look at the front of the mower. On your front right side is your air filter. Remove the air filter, I believe that coincidently your air filter got to the point where it couldn't breathe anymore, meaning clogged to the point of choking. You can tell by putting it up to sun light and looking through it. If it's very very dirty , it needs to be changed. Also if there is a choke, it would be just behind the air filter. If it blocked off the end of the carburater then the choke is on. If this is the case then follow the rod that moves the choke. Possibly it was bent when you went under the bush. I believe you will find that your problem lies with a dirty air filter.
Posted on Jun 14, 2011
What is the spark plug to use for a Poulan Pro 550 series, 158cc engine?
what ever you took out put back in or j19lm champion
Oct 01, 2014 | Garden
My poulan pro 550 series is vibrating a lot when I started. And the front wheel drive is not working anymore.
you need to unplug the spark plug then turn the mower on its side sounds like you hit a rock and bent something and if you bent the crank the belt might have fallen off
Jul 01, 2012 | Poulan Pro PR550N22SH 22Inch Briggs ...
Poulan pro honda engine stalls as auto choke lever moves
it sounds to me that there s a jet inside the carb that is still plugged
Jun 24, 2012 | Poulan Pro " Pro" Self Propelled Mower
Oil plug location
there is a drain plug on the bottom of the engine near the crank but it is faster to turn the mower on its side and drain it from the dip stick hole
Apr 01, 2012 | Poulan Pro PR550N22SH 22Inch Briggs ...
I have a Poulan 550 158cc Push Mower. Two Model #'s 96132004200 and PR0550N21RH3. Two Serial #'s 0901075421770 and 011309M001762. The mower will run if primed then dies. The carb. is on the tank. I...
does it have fresh gas in it, If so time to rebuild the carb, even though you blew through all holes there is a diaphram inside the carb that pumps gas to it, so I suggest you take the carb apart and clean inside out and replace the diaphram, the way you describe it only runs on primer, tells me the carb is not getting fuel. Good Luck
May 14, 2011 | Poulan Pro PR550N21R 21Inch Briggs ...
Cannot find drain to change oil.
Poulon 550 yellow 22" Briggs and Stratton. It looks like you have to drain it out the cap by tipping it. There IS no plug on mine - spent 40 minutes looking for one, and I know what both types of the plug look like. What a lousy design. This mower is a piece of junk. The valve froze a week after I got it. Never again. A headache.
Dec 13, 2010 | Poulan Pro PR550N22SH 22Inch Briggs ...
Poulan 550 Series push mower won't pull start
Hmmmm,,and the plot thickens. Without seeing the unit, i would have to think that when you pull the engine control cable bar, its not releasing the brake that sits against the flywheel. These cables do stretch. Pull the engine cover and you will see the brake against the flywheel. Pull the engine control handle and watch and see if brake is releasing. If its not, replace the cable.
That would be my bet. I hope this is of some help.
May 28, 2010 | Poulan Pro PR550N22SH 22Inch Briggs ...
Poulan Pro PR550N22SH 22Inch Briggs  Stratton 550 Series Gas Powered Side DischargeMulch Lawn Mower With High Rear Wheels (NonCARB Compliant) () Logo
613 people viewed this question
Top Poulan Garden Experts
dannydoesita
Marvin
Marvin
bryan st
Are you a Poulan Garden Expert? Answer questions, earn points and help others
