SOURCE: Toner light won't stop blinking
Try resetting it, open front cover hold down silver button, all lights should flash rotatingly, when stopped turn off and on and close door.
SOURCE: Blank pages after installing new drum
when replacing the toner did you remove the plastic film sealing the toner? if the drums receives no toner you will get blank pages. please check
hope this helps
good luck
SOURCE: Toner light still on with new toner
Is the printer still asking for a new toner..?
If it is the there is a gear that can be reset on the toner cartridge to tell the machine its a new toner cartridge. This is normally done by an engineer, but is quite easy to do if you know how. And I do :0
Toner light is ON, I would assume that the light is solid and not blinking. You can press and release to clear the light sequence and continue processing the print job. With the printer turned off, remove the toner cartridge and shake it to extend its life. Check the replacement toner cartridge if it is the one suitable for your region.
If the blinking light is on Toner Low, press and release the Continue button (green button) to clear the light sequence and continue processing the print job. If the light is still blinking, the photoconductor is almost full and should be replaced.
For further assistance, please call Lexmark Technical Support.
