Master
- Posted on Jun 14, 2011
Re: New batterys fitted from lucas worked fine 40 mins...
- Well when the battery clicks like that it is an indication of either a loose connection of the battery has died.
- First thing is to make sure that battery got a real good charge first before using the scooter. half a charge won't do much especially being new.
- Now if some of the metal plating has come off of the connector it is possible the connection is not quite doing it at that point. Imagine how a car sounds when you try to start it and the battery clamp has come a tad loose... click click click click click.
- In this case you need to try a new connector. You can try the place you got the gogo scooter from or this place sells many scooter parts http://www.monsterscooterparts.com/mobility-battery-chargers.html
- Make sure the fuse is good and check all wiring for a direct short. Make sure non of the insulation has been negated.
- Get out a multi-meter and set it to DC and start testing the power feed wires for 12v DC power. Check the ground wire as well and make sure the polarity is 0. If the is polarity in the ground wire anywhere then there is a short somewhere for sure. Start at the connector and move down.
- Make sure the battery charging unit/cables are functioning properly as well. If the charger is not charging properly it would be hard for the battery to perform properly.
- Hope this helps and thanks you for using FixYa.
Regards,
Tony
very good easy to fit
