Common problem with this TV is the power supply module.
Check the power supply; look for bad caps with leaking/bulging tops, check to see if you have standby +5vdc at the power supply connector, the front red indicator will not be on if you do not have this +5vdc standby voltage due to shorted out power transistor and zener diode, If otherwise you contact the manufacturer or a skilled qualified personnel to handle the fault..
Hoping that will help to solve the problem....
