SOURCE: plumbing connection to dishwasher leaking
Remove bottom panel and run dishwasher while monitoring it. A large leak may be from a hose off at pump underneath. Mice can chew holes in hoses too.
SOURCE: heating element broken, water leaking
You have to pull out dishwasher to replace the element.The element is easy to replace once you have pulled dishwasher out.This enables you to reach the area that you need to reach.It is common for a element to brake.On a newer dishwasher ,I would say it must have been defective if it just broke in half.Nothing electrical in a dishwasher can cause it to brake.
SOURCE: tank is leaking
Is it the tank or just the door seals? Ours was leaking recently, there was an obvious tear in the door seal. Once fixed no probs.
SOURCE: error code 01 on elecrolux dishwasher EIDW6305GSI
Usually the error code 01 means you backed up water in the unit. First be sure that the drain is clear. Run the garbage disposal and be sure your sinks are draining.
I got lucky on a EIDW6105 unit by trying this.
All the lights are flashing and it shows error code 01.
Push down on two of the buttons and hold (I pushed on the Favorite and Heavy buttons), until the flashing stops (about 8 seconds).
The machine now showed and error code 08. Then hit the start button. My washer then cleared and runs normally.
Hope this helps, better than a sevice call to clear the code.
SOURCE: model 15754 Kenmore built in dishwasher leaking
take off the bottom panel ....... check for the leak .... could be the fill valve connection ..... motor pump assembly (most liklely) or a drain hose/pump issue....if the DW is noisy as well go shopping ...
