Question about Hayward H Series Electronic Ignition 250,000 Btu Pool Heater H250ped2
I have a Hayward H250 that wont ignite. When I set mode to to pool the blower comes on but nothing kicks in. then i get an error code of AO.
Posted by frank741 on
  • frank741 Jun 14, 2011
    How do check the automatic reset? Is there somthing wrong with the blower switch. If the heater is leaking from any of the plugs could that be a factor?
D. Floyd Kolb
  • 43,501 Answers
The blower is not closing the vacuum (pressure) switch or the switch is bad...
Check the blower to make sure that air is coming out and that the volume seems to be normal...a plugged heat exchanger can cause the air to be restricted and the switch will not close...
If all seems normal, then replace the switch...
heatman101
Posted on Jun 15, 2011
Aloke Das
  • 1,833 Answers
ErrorAO means BlowerVacuum Switch Open. If the blower prover switch does notclose after the blower starts the control will stop the ignition trial go intolockout. The blower will continue to run. Automatic reset is immediate afterthe switch closes. So you need to check this.
Posted on Jun 14, 2011
Ao error message in Hayward heaters
You didn't indicate exatctly which model you have. But on most the AO error code is :Blower vacuum switch
open error If the blower prover switch does not close after the blower starts the control will
stop the ignition trial go into lockout. The blower will continue to run. Automatic reset is immediate after the switch closes.Check to be sure combustion blower starts
If you don't have your manual you can download one for your exact model at : www.haywardnet.com
Jul 29, 2010 | Hayward H Series Pool & Spa Heater 400k...
I had code AO displayed on my hayward H250IDE. I
Check your wiring again on all the safety devices - Water pressure switch and both Hi- limits in the header.
Feb 19, 2010 | Hayward H Series Pool & Spa Heater 400k...
AO error
This error is produced when the blower prover switch does not close after the blower starts, the control will stop the ignition and go into lockout. Automatic reset is immediate after the blower prover switch closes.
If you keep having this problem, contact a reputable service company, especially if it's under warranty.
The link to the owners manual is below, it references fault codes, etc..
Hope this helps.
http://74.125.95.132/search?q=cache:4mAdY7bLfoQJ:www.haywardnet.com/products/Manuals/pdfs/Manual227.pdf+hayward+AO+error&cd=7&hl=en&ct=clnk&gl=us
Sep 16, 2009 | Hayward H Series Pool & Spa Heater 400k...
AO error code
I would have to agree with you concerning the control module.
Jul 31, 2009 | Hayward H Series Pool & Spa Heater 400k...
Pool heater will not ignite
My heater worked ok , btu made a clicking sound, now it shows a AO error? What can I do I dont have enough money to call a pool man again.
Jul 03, 2009 | Hayward H Series Pool & Spa Heater 400k...
Hayward H Series Electronic Ignition 250,000 Btu Pool Heater  H250ped2 Logo
689 people viewed this question
Top Hayward Pool & Spa Experts
john h
Marvin
Marvin
Paul Carew
Are you a Hayward Pool and Spa Expert? Answer questions, earn points and help others
