Question about Cobra 18-Mile, 22-Channel FRS/GMRS 2-Way Radios
Replaced batteries. But I can't turn it on. Please advise.
Posted by john_harv488 on
wcrave
    New Friend:
    Problem Solver:
  • 19 Answers
Make sure the batteries are installed properly.
Posted on Jun 29, 2011
2005 Kia Rio - sometimes won't start, but has a new battery
I once had a chvy lumina car that had a similar problem. I ended up replacing the alternator that was not charging up the battery. The battery was replaced first and then the alternator. In addition, the electronic motherboard was replaced underneath the coil pack. I did all the work myself. No more electronic problems. If they did a diagnostic test on your car and it showed a bad battery then the battery should be tested by Autozone. Go to Oreilly's too for test.
Jan 20, 2018 | 2005 Kia Rio
1991 Miata Help! Won't start, nothing at all on key turn, STILL after battery replacement. Help!
The main fuse blew. Look in your fuse box for a big fuse it should be labeled main or master fuse. Replace this fuse and vehicle should work everything but maybe the starting issues. You have a short somewhere. If the fuse blows again or the car won't start repost the problem
Oct 18, 2017 | Mazda MX-5 Miata Cars & Trucks
Horn does not work. Have replaced horn relay & fuse and it still isn't working. Please advise
Check to make sure that horn is connected at the steering wheel.
Remove the portion of the wheel that you push to activate the horn
and reconnect the wire. If that doesn't work check connections at
the horn(s).
Jan 01, 2013 | 1999 Plymouth Voyager
Battery life nikon coolpix s3000
If the rechargeable battery is more than 3 - 4 years old then the battery could be worn out. Rechargeable batteries have a finite number of charge and discharge cycles and will lose their charge capacity over time, i.e. won't charge to 100% and gradually the charge reduces until the battery won't charge up at all. OR The battery shows a 100% charge but when the adapter is disconnected the battery drops off to zero capacity in a very short time. If the battery drops to an unacceptable charge level then the battery needs to be replaced. Rechargeable batteries will fail if stored in a discharged state for long periods.
Oct 06, 2012 | Nikon COOLPIX L18 Digital Camera
How to charge the battery, philips govibe
If the recharageable battery is more than 3 - 4 years old then the battery could be worn out.Rechargeable batteries have a finite number of charge and discharge cycles andwill lose their charge capacity over time, i.e. won't charge to 100% and graduallythe charge reduces until the battery won't charge up at all. OR The batteryshows a 100% charge but when the adapter is disconnected the battery drops offto zero capacity in a very short time. If the battery drops to an unacceptablecharge level then the battery needs to be replaced.
Mar 28, 2012 | Philips GoGear ViBE Digital Media Player
Polaroid A500 digital camera pressed ON button, nothing happened with new AA batteries and SD card
Things to check first for a camera that won't turn on are battery contact points, and micro switches that are located on the battery and memory card doors. Troubleshooting tips on other things that need to be checked may be seen here. These tips won't work for every case, but they're worth a try.
Nov 25, 2011 | Polaroid Cameras
I just replaced battery and alternator on my 1999 ford f150, still wont turn over, need advise
I'm assuming you mean it won't crank.I believe Fords still have an external stater relay,try shorting acroos the two large terminals with a screwdriver.If it cranks by doing this,verify you get 12 volts on the smaller wire when you turn the key to the start position.If you do,then its the relay.
Sep 09, 2011 | 1996 Ford F150 Regular Cab
My htc p3450 turns itself off while im not using it , i then have to completely restart it
Hi there!
Since you've mentioned that your phone keeps on turning off then ill be advising you to please check if your battery is properly holding a charge because it might be that your phone doesn't have enough power.so if the problem is your battery then kindly purchase a new one to prevent other issues.
Thanks!
Apr 17, 2011 | Cell Phones
I have a cub cadet zforce 48 zero turn. It starts right up, but when I take the brake off it shuts off.
Can't get my Cub Cadet started. We've replaced the battery, checked the seat sensor all is good. Any advise would be appreciated!!
Thanks
Angie
Apr 07, 2009 | Cub Cadet Street Sign- tractor lawn riding...
Cobra 18-Mile, 22-Channel FRS/GMRS 2-Way Radios Logo
27 people viewed this question
Top Cobra Radio Communications Experts
Michael Thomas
Michael Thomas
Marvin
Marvin
Are you a Cobra Radio Communication Expert? Answer questions, earn points and help others
