This assumes web pages fail. if not pingtest.net is one of many great sites to test connection speed.
Select 'Start' button Select 'Run' Type 'cmd' Select 'Ok' This opens a command window. Black with white text. Type "ping 4.2.2.2" without quotes. If you see "reply from" then you are connected but you may need to test DNS resolution.
DNS test:
Same command window. Type "ping pingtest.net" without quotes
If you get a 'reply from' then you can resolve DNS.
If any of these ping test fail start with resetting your connection, see ipconfig /renew and/or ipconfig /flushdns then reviewing your connections and possibly contact your ISP.
Doing a Repair on XP - Vista - Windows 7 does the same (but more) as ipconfig.
Hi just read your posting.Error code 130 means you have an error known as SINGLE ROTOR POSITION SENSOR ERROR.This means either the rotor sensor,which is attached to your motor, is faulty or the wiring to the rotor sensor is faulty or your control module is faulty.To test the rotor sensor you need a device called an RPS tester.I can help you check the wiring to the rotor sensor but unfortunately I can not help you test the rotor sensor without you having an RPS tester.Also to help you test the wiring can you borrow or have you got an electrical test meter .Please reply on how you would like to proceed and I will help you as much as I can. Looking forward to your reply.
Hi just read your posting.Now error code 49 means either your cold water valve is faulty,or your wiring to the valve is faulty or your motor controller is faulty.Have you or can you borrow an electrical test meter?If you can get a test meter I can guide you throe step by step in the testing of the valve and wiring.Please reply and let me know how you would like to proceed.Looking forward to your reply.
Hi just read your posting.Now the problem could be your motor or motor module.Have you got or can borrow an electrical test meter to test the motor and wiring? Please reply back and and I can guide you the finding of the fault and the repair.Also I will look at my manual to see if you can test for the fault without a test meter.Looking forward to your reply.
Hi just read your posting.Now Error code 43 means you have an OUT OF BALANCE SWITCH FAULT.The switch is located under the control module which is located under the top panel.Would you like me to guide you throe the testing and possible replacement of the Switch?The secondary source of this error code is your Motor Controller.But we must test the switch 1st as the switch is the most likely component that is faulty.Have you or can you borrow an electrical test meter to test the switch.It would make it easier to test the switch with the tester but there are ways around this.Please reply for further assistance and I am sure I can help you rectify this fault.Looking forward to your reply.
Hi just read your posting.Error Code 49 means your Cold water valve is faulty,Or your control module is faulty.To test this fault you need an electrical test meter to test the water valve coil for conductivity.Have you or can you borrow a test meter to check the water valve?Please reply on how you would like to proceed and I am sure I can guide you throe the steps needed to rectify this fault.Looking forward to your reply.
You are saying you cannot connect through the router ... Change the ethernet cable and/or try other portson the router.
Does your computer connect to the WWW when you wire it directly? If it will work when connected directly then it should work through the router. That is your test.
