I had same problem, just fixed it by a little hack. The volume up switch is broken.
1. Remove accessory door on bottom. 2. Remove all screws on back. 3. Open back cover.
Looking at the exposed board, there are 2 volume switches (back to back). Directly next the switches are four contacts: the upper 2 are for volume down, the lower 2 are for volume up.
4. Place the battery pack on the board and hold it down. 5. Press the power button to turn on the unit. 6. Use a small wire to jump the volume up contacts multiple times to change the volume to maximum (or desired level). 7. (Optional) Remove the volume buttons and throw away the rubber cushions to prevent the volume from changing. 8. Replace everything back in place.
thank you for the tip. it was very useful. i did it and it worked. my 4 yr old daughter is very grateful!
hi Joe,
I'm not sure where the 'volume contacts' would be located. how can i identify what these are/look like? please help. thanks.
hi Joe,
i'm not sure how to identify what the 'four contacts' are. can you explain what they look like please? and if they are on the front or the back of the motherboard. thanks!
They look like shiny metallic dots directly next to the volume buttons on the back of the board. You should see them after you remove the back cover.
hi Joe, thanks so much for your response. one more question, I don't have a wire so I've used a safety pin to touch the contacts but nothing happens. is there a specific motion required to get the volume to change?
Works like a charm!! My 5 yr old daughter is once again happy that she can play her Explorer. THank you so much!!!!
Nope, there are no special motions. Unlike many sports, the key is not in the wrist; it's just a matter of closing the circuit.
I followed the instructions to above to open the back (bottom screws/plate, battery pack/rechargeable battery pack, remove screws from back) I then noticed that the small connecting metal directly behind the up volume button had broken where it was soldered. I then took a nail file and pressed the metal extension to the grid (small silver bubble underneath it). I replaced the back (be careful of the spring on the large green top button/there is a sliding bar that popped out on me) and the volume works correctly now. Hope this helps!
My Leapster 2 had the same problem. I used your steps to fix it. The difference was the connection point was around on the front. So I wiggled a flat head screwdriver into the front where the up button is. Worked great.
I had the same issue, but I fixed it by Repairing through LeapsterConnect. Just connect your Leapster and when it is ready hit the Settings on the right up corner. Then choose Repair button; you also can hit Reset, but it will erase everything from your Leapster. For me it worked.
Do not take it apart!
It's not leapsterconnect, it's leapfrog connect!
I've not seen posts about this issue but my sons touch screen quit working
go to settings
