Question about Dacor DMT2420 1200 Watts Microwave Oven
I have a six year old Dacor DTM2420s microwave that will not begin the heating process. The oven was running, I then heard a slight pop noise and saw the turntable reverse. I then opened the door and the turntable kept going. Now the keyboard does not go back to the clock screen and when I hit the start button the timer counts down but the turntable does not move and I do not hear the heating mechanism turn on.
Posted by tony_spad on
D. Floyd Kolb
  • Dacor Master
  • 43,501 Answers
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101 ;
Posted on Jun 18, 2011
Microwave does not heat and makes a lot of noise
hi Richard, from experience i would say the power supply to the magnetron is at fault, you must take extreme care if you intend to test the supply as the high voltages involved...
Regards
Rob
Dec 07, 2015 | Dacor Microwave Ovens
Microwave door wont stay closed
replace the door hooks and door release button.
if this is broken the switch will not close very well, and NOT start the microwave.
God bless you
Jul 19, 2012 | Samsung SMH9187 Microwave Oven
Microwave panel is on, timer works, but no turning or heating. unit is 3 years old
Bottom door switch or mount.
See this file, and the DMT2420 manuals here and here.
You can order Dacor parts by part number from the Pros here.
Aug 14, 2011 | Dacor DMT2420SS Microwave Oven
I was heating my tea and I heard a loud pop and the unit turned off...I thought I had blown a fuse and went out and checked fuse box..flipped all fuses and microwave still not turning on at all...micorwave...
The description you provide indicates the magnetron has failed, "heats food" and blown the main fuse in the microwave oven, since the unit is 10 years old it is much cheaper to replace with a new one rather than have it repaired.
May 15, 2011 | Amana Radarange Microwave Oven
Less than 5 years old - Microwave Panel lights up, turntable turns, fan works - everything works except it doesn't heat food. Heard a pop, and now it runs louder than before but doesn't heat. Any ideas?
That pop was the magnetron frying. This is a repairable problem, but feirly expensive, around $300 if you have it done by a professional.
Please rate my response if it was helpful to you.
Thanks, Repairman45.
Dec 02, 2010 | Frigidaire PLMV169DC Microwave Oven
Ge over the renge microwave runs but no heat
heatman101
hjdhjd
Feb 13, 2010 | GE JVM2070 Microwave Oven
Saw sparks and heard a pop noise when we hit ''start'' on microwave
We just had the same problem - spark, loud noise, and then dead. At first I replaced the ceramic fuse and the same thing happened immediately. A local appliance store tested the transformer and found it was "bad." I purchased a used transformer from the store for about $35. I installed both of these myself with little effort.
Sep 08, 2009 | Dacor DMO24SS Microwave Oven
The micro wave heats but won't pop popcorn. We do more time than required but 50 - 70 % OF THE KERNELS DON'T POP.
How old is your popcorn? If it's over a year old in the pantry and not in the fridge it tends to dry out/shrible inside. Or...note that these days instructions indicate between 2 types:
regular hot air popping method and microwave friendly popcorn. You can buy hot air poppers cheaply at many resale shops.
Jul 25, 2009 | Dacor DMT2420 1200 Watts Microwave Oven
Buzzing (a little bit louder than normal humm), but no popping
WHEN THERE IS A BUZZING NOISE IT MEANS THAT ONE OF THE INTERNAL COMPONENT HAS FAILED .RANGING FROM A SMALL DIODE TO LARGE PARTS LIKE
THE MAGNETRON OR TRANSFORMER OR CAPACITOR. IF IT IS 10 YRS,OLD YOUR BETTER
OFF GETTING A NEW ONE .BECAUSE YOU COULD INVEST MONEY IN THIS ONE AND HAVE SOMETHING ELSE GO TWO DAYS FOR NOW.WITH A NEW ONE YOU ALSO END UP WITH THE NEW WARRANTY. HOPE I HELPED. KEN62 GOOD DAY!
Jul 22, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Dacor DMT2420 1200 Watts Microwave Oven Logo
296 people viewed this question
Top Dacor Microwave Ovens Experts
William Miller
William Miller
Michael Thomas
Michael Thomas
Marvin
Marvin
Are you a Dacor Microwave Oven Expert? Answer questions, earn points and help others
