Consider NOT using the Vivitar software.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program, such as Picasa.
SOURCE: Free Download for Vivitar Experience Image Manager
Could not find a download for you on their website.
You know you can download your pictures manually without the image manager. From the manual:
1. Use the USB cable that came with your camera to connect your camera to your computer.
2. A window appears with a list of options, select Open folder to view files and click OK.
3. Open the DCIM folder and the folder inside to view the media files.
4. Select the media and copy the files from this folder into your computer. Optionally, select the files and choose Copy from the Edit menu. Then select a folder and choose Paste from the Edit menu.
5. We recommend that you copy the images into the Pictures/My Pictures folder and the videos into the Videos/My Videos folder.
6. Do not disconnect the cable during transfer. Doing so will cancel the transfer of any files on their way to your computer.
If you still want to try to get the Image Manager software, I would suggest contacting Vivitar support at:
[email protected]
OR
In the US: 1-800-592-9541
In the UK: 0-800-917-4831
In case you do not have a manual, here is a link:
http://www.vivitar.com/products/14/ViviCam_8225_Camera_Manual.pdf
Thanks for using Fixya.
Happy New Year!
SOURCE: vivitar exoerience imagge manager installer not
Suggest yo contact Vivitar support at:
Customer Support
[email protected]
US: 1-800-592-9541
UK: 0-800-917-4831
SOURCE: Vivitar Experience Image Manager Setup CD Doesn't Load
here is the solution
there is an error in the disk reference
(res://ieframe.dll/dnserrordiagoff_webOC.htm#http://www.vivitar-experience-image-manager.com/setup/1_choose_language.php?locale=en_US&os=Windows&ver=1)
the error is this part
solution is to open up your internet browser and go to this link
SOURCE: i need to download Vivitar Experience Image
http://www.vivitar.com/products#Digital Cameras/24/13/Support
check this link for all your needs on Vivitar8025 Experience software
