Question about Texas Instruments TI-89 Calculator
Ti 89 titanium when multiply 2x2 matrix by 2x1 matrix get error diemensions
Posted by dfsykes on
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Texas Instru... Master
  • 102,366 Answers
Matrix multiplication is defined only when the width of the first matrix is equal to the height of the second. You can multiply a 2x2 matrix by a 1x2 matrix or multiply a 2x1 matrix by a 2x2 matrix, but you cannot multiply a 2x2 matrix by a 2x1 matrix.
Posted on Jun 13, 2011
Error: Non-algebraic variable in expression
Non-algebraic variable in expression: error 790
If a is the name of a PIC, GDB, MAC, FIG, etc., a+1 is invalid. Use a different variable name in the expression or delete the variable.
Apr 22, 2015 | Texas Instruments TI-89 Graphing Calc...
How do you square on a ti 89 titanium
One way is to multiply the quantity by itself.
Another is to raise it to the second power using ^ (just above the divide key).
You can also take it's logarithm, double it, then take the antilog :-)
Apr 27, 2014 | Texas Instruments TI-89 Calculator
Matrix/scalar
Sorry, but your matrices do not make sense.If you multiply a matrix by a scalar the resulting (product) matrix has exactly the same structure as the one you multiplied : (mXn) times a yields another (mXn) matrix.
Be it as it may, when you multiply a matrix by a scalar, you obtain the product by multiplying every element of the original matrix by the scalar.
Here is a screen capture showing the multiplication of a 2X2 matrix by a scalar.
Note: I have noticed that screen captures I insert in my answers are sometimes deleted (by FixYa?). So if you do not see a picture it has nothing to do with me.
Dec 11, 2011 | Office Equipment & Supplies
I am dividing a 3*1 matrix with a 3*3 matrix with numbers in polar format and it gives me the error data type error.
You'll get the same error if you try to divide two matrices with real numbers. The TI-89 doesn't allow you to divide a matrix by another. However, you can multiply a matrix by the reciprocal of the other.
For example, to calculate A/B, calculate instead A*B^-1 . Makes sure you use the (-) key just to the right of the decimal point key to put in the negative sign before the "1".
Sep 10, 2011 | Texas Instruments TI-89 Calculator
My TI-89 Titanium's screen froze. Well actually, the cursor kept blinking but none of the buttons worked. I got it to restart using the (-) and ) button trick, but rather than going back to normal it went...
Hi kelsers,
You need to re-install your calculator's OS. After this process your Ti 89 Titanium will operate properly. If you do the process below make sure you use new batteries.
Warning!!! If you do this procedure make sure that your computer and, calculator are connect. Use Ti Connect software and, make sure you can install the OS on the calculator without any interruption. At any time even at the very beginning of this process, if your computer or, calculator gets interrupted or you have a power failure during the installation of the OS, your calculator will be destroyed. So not attempt this procedure during a thunder storm.
You can use the Ti OS Downloader but, you will have no idea what OS is stored by the Ti OS Downloader. So, I suggest following my instructions and, installing the newest Ti 89 Titanium OS 3.10v.
Procedure to installing the newest Ti 89 Titanium OS 3.10v.
You can also get the latest copy of Ti 89 Titanium OS 3.10v by going to the Texas Instruments web site. You can get to that site instantly by clicking, "Ti 89 Titanium OS 3.10v." Once your at the Ti site click the Download Item, Ti 89 Titanium OS 3.10v. Next you can login or, click "continue as guest". I'd would click the "continue as guest". Once you have click, "continue as guest" the Ti 89 Titanium OS 3.10v. will download to you. Click, "SAVE". And then a folder will pop up. It is probably a folder that you download too. If so, you may want to change it and, "Save as" to this folder, "My Documents \ My TI Data \ Downloads". You can also go back and, download the Ti 89 Titanium guidebook too, if needed.
Link your computer and calculator with the USB cable or, Direct Black Link cable that came with the calculator.
Remove one of the AAA batteries. Press and hold the [APPS] key, and while holding the [APPS] key, replace the battery and turn the unit on. On the older TI-89 you should see "Press I to install code...", and you should press the [9] key to continue. But, on your Ti 89 titanium it should say, "Waiting to receive..." or, "Waiting to received OS...". Now you need to follow the instructions in the paragraph below to restore the calculator's operating system.
Next, drag the Ti 89 Titanium OS 3.10v. that you copied earlier to "My Documents \ My TI Data \ Downloads" out of that folder and, drop it in the "Ti Connect" icon on the desktop. Next the OS Downloader Warning will pop-up. Click, "OK" to continue and, the new OS will begin to install. The Ti Device window should pop up and, click on to the port where your Ti 89 Titanium is located, USB1 cable or Direct Black COM1. Just click, "Select" and, the OS will continue to download. Upon completion the newest Ti 89 Titanium OS 3.01v. will be installed.
Jan 10, 2011 | Texas Instruments TI-89 Calculator
Ti-89 titanium
Having gone over a month with no response, I assume this is no longer a problem.
Jun 26, 2010 | Texas Instruments TI-89 Calculator
When I turn the switch on, ti-89 titanium does not turn on.
If you connect calculator to computer using Ti connect device explorer you might be able to see what files are on the calculator. I don't know if you downloaded from the web but, 3rd party programs and shells tent to miss up the calculator. This would able you to delete out possible problems which could be re installed later.
Sep 22, 2009 | Texas Instruments TI-89 Calculator
Trying to get the inverse of a matrix
The error may be due to the key you used to signifie inverse. It says in the manual that you should use the key x^-1 not the one used to input general powers.
Here is screen capture from the Appendix to the manual. The picture shows the sequence of keys to press to obtain the inverse of a 2x2 matrix. It is taken from page 41 of Appendix
The matrix used in the exemple is
a_11=2 a_12=1 a_21=1 a_22=2
Here is the link to download the manual and the appendix
http://support.casio.com/manualfile.php?rgn=1&cid=004001004
Hope it helps
Jul 13, 2009 | Casio FX-115ES Scientific Calculator
How do i multiply a (2x2) matrix by a (2x1) in the ti 89
The so-called (2x1) matrix is not a matrix. It is a vector.
Hope it helps.
Apr 26, 2009 | Texas Instruments TI-89 Calculator
Texas Instruments TI-89 Calculator Logo
Top Texas Instruments Office Equipment & Supplies Experts
k24674
Paul Bade
Daniel Dollive
Daniel Dollive
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
