Question about Frigidaire 14 cu. ft. / 396 liter Upright Freezer FFU14FC4A
Kenmore elite upright freezer, model 253.26072100. On the electronic temperature control panel it reads OFf. What does this mean?
Posted by lindsayborgm on
  • 2 more comments
  • lindsayborgm Jun 13, 2011
    I did download the manual, however I have the Deluxe Electronic Temperature Control; and it states to refer to the electronics Control Guide supplied, which I cannot find online.
    I have tried this, but nothing changes. I have also unplugged the machine and pushed all of the buttons, and nothing happens.
    The only buttons on the freezer are Quick Freeze, up and down arrows, and Reset/Alarm buttons.
    THANK YOU!!! It worked!
Andy Turner
  • 910 Answers
OFF indicates that the Temperature Control is switched Off.
Pressing the Up or Down Buttons should change the display back to the Temperature Display and allow you to set the required Temperature.
Posted on Jun 13, 2011
  • 1 more comment
  • Andy Turner Jun 13, 2011
    It sounds like its been switched into what they call Sabbath Mode which turns everything off but the compressor. Try pressing and holding the Control Lock & Temp Display buttons together for 3 seconds.
    OK, So the control are as shown in the User & Care Guide and not the Electronics Control Guide, but from the Electronics Control Guide is states. -
    So although your controls are those shown in the User & Care Guide, in the Electronics Control Guide it states. - You may also turn off the freezer by pressing the UP arrow
    button until the display reads "10". With the display at "10', press the Up Arrow button two more times within two seconds. The display will read "OF". The freezer can be turned ON by pressing the DOWN arrow button, with the display -10, two times within two seconds. Continue by setting the control to the desired temperature.
Jyackle5
  • 8,197 Answers
That means that the frezer is off. You need to set the frezer on a temp to turn on. You can get the manualon the link below.
http://www.managemylife.com/mmh/lis_pdf/OWNM/L0603500.pdf
With deluxe Electronic Temperature Control Freezer control panel shows "OF" and I can't restart the freezer
Search Results
    Freezer electronic temperature control manual... ' Sears ...
    www.searspartsdirect.com > Ask an Expert
    Jul 5, 2012 - I have a Kenmore elite freezer with electronic temperature control. ...my freezer was delivered yesterday, the control panel is stuck on of, ... an electronic control on front. the display is showing hi temp and door ajar. also an l in ...
    Control Panel is not working right - Samsung
    www.samsung.com/sa_en/support/skp/faq/239315
    Samsung ElectronicsSep 3, 2015 - In case of wrong temperature display, possibly door opens so inside ... If the control panel is still not lit up after you plug the refrigerator back in, it may ... When initial installation, Temperature will show current temperature for a ... When the refrigerator/ freezer reach the set temperature, the blinking will stop.
    Adjusting Side-bySide Refrigerator Temp Controls - Actual ...
    ? 3:50
    https://www.youtube.com/watch?v=DFzTGKVo79g
    Jun 27, 2010 - Uploaded by GE Appliances
    CAN I TURN OFF THE DIGITAL CONTROL ON FREEZER AREA ONLY. ... I need to know How to reset this kind of refigirator, same front panel ... When you try to set the actual temperature, does your control show your new ...
    Electronic Temperature Controls - ManualsLib
Feb 03, 2016 | Freezers
Does Kenmore Elite upright freezer reach -20 degrees celsius, where is the info?
Best way I can answer this is to purchase the right equipment for the job. A domestic freezer is not designed to work like that, although it may get there in temp it won't hold it. Recovery is slower then the industrial unit you seek. Domestic unit warranties are void if used for commercial settings (i.e. lunch rooms, offices, lab's, etc...) I wish I had a better answer for you but if you need a specific temperature get the correct equipment for the job. Good Luck
I’m happy to help further over the phone at https://www.6ya.com/expert/gere_bf68e6055dd61249
Jul 31, 2014 | Kenmore 20.6 cu. ft. Upright Freezer 2809
Lffh21f7hwa
Hello Michael - Sounds like the temperature control was accidently turned OFF. When this occurs the temperature control turns off the compressor, but does not disconnect the power to the light bulb or other electronics. Let's try activating the freezer by pressing the UP arrow until display shows "4" or desired setting. Allow 24 hours for temperature to stabilize. For future reference you can lock the control to keep from accidently changing the temperature setting. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if the unit's status has changed successfully. Thank you.
Jul 01, 2013 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
I have a 2007 model 253.264 upright Kenmore self-defrosting freezer. The control panel on the front door stopped working. No temperature reading and no way to adjust controls. The freezer is still
I have one out in the yard that is doing the very same thing. Works good but the door display is out. I looked underneath and all of the wires seem to be connected. The main control board is on the bottom as well. The battery is also new. You must have a broken wire between that control and the main board below. I imagine it has something to do the the connector that goes through the door.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Sep 21, 2012 | Kenmore 13.7 cu. ft. / 388 liter Upright...
Just bought a used kenmore elite frost feee freezer model 3 253.26072100 with an alarm and in great shape however there is no manual and we do not know how or what the temp settings should be at. We have...
You can view/download the manual at
http://www.managemylife.com/mmh/owner_manuals/8259/KENMORE-ELITE-Upright-Freezer-L0603500
Jul 16, 2011 | Kenmore 20.3 cu. ft. / 575 liter Upright...
Kenmore® (46-26072) Elite® 20.6-Cu. Ft. Frost-Free White Upright Freezer
Check these two things first.  1.  Is there a thick frost buildup on the back panel at the bottom half of the freezer?  2.  Do you hear the fan running inside the freezer?  Let me know what you find.
Oct 12, 2007 | Maytag Freezer MQU2057
Frigidaire 14 cu. ft. / 396 liter Upright Freezer FFU14FC4A Logo
3,105 people viewed this question
Top Frigidaire Freezers Experts
Muntejaya Ginting
Muntejaya Ginting
Dennis Boxerman
Marvin
Marvin
Are you a Frigidaire Freezer Expert? Answer questions, earn points and help others
